Go Back   The RadioReference.com Forums > Announcements
Amateur Radio Equipment - For general and technical discussion of Amateur Radio equipment such as transceivers, repeaters, controllers and receivers.
View All Announcements (3) Global Announcement
01-01-2013 until 01-28-2025
Forums Manager Forums Manager is offline
Super Moderator
Negative posts regarding encryption and audio streaming will now cease
Effective immediately we will be deleting, without notice, any negative threads or posts that deal with the use of encryption and streaming of scanner audio.
We've noticed a huge increase in rants and negative posts that revolve around agencies going to encryption due to the broadcasting of scanner audio on the internet. It's now worn out and continues to be the same recycled rants. These rants hijack the threads and derail the conversation. They no longer have a place anywhere on this forum other than in the designated threads in the Rants forum in the Tavern.
If you are found to violate this announcement you post will be deleted without notice and an infraction will be issued. We are not against discussion of this issue. You just need to do it in the right place. For example:
http://forums.radioreference.com/ran...ncryption.html
To contact me please use the forum email function as I do not accept Private Messages unless you're on my contact list.
All rules and guidelines are covered in this forum. These are required reading for new members and all existing should follow for any updates.
