darticus
Do you need your license to buy a ham unit? Ron
If you want to build a nice beam antenna, google Kent Britain cheap yagi or tape measure antenna. If you want to buy, check out the arrow2 or elk handhelds, they are good on 2 meter and 70cm and work well to get on the amateur FM sats
RON hows goes it? having fun with the ham stuff, now that you got your ticket?
DAN KC2WCM
Having fun and looking for ways to get out and receive better. Maybe a small beam??? Thanks Ron
You can try making a " J " pole antenna out of 1/2 inch copper water pipe inexpensive and works GREAT i have one i made inside, in the corner of my bedroom works great i can give you the plans. Or you could buy a regular 2m/440 antenna with a mag. mount and attach it to a cookie sheet for a ground plane and wala quick cheap useful antenna. you are in a tough area for a handheld radio... you can get a million different idea's here im sure... i just stated two of the easier ones...ill listen for ya on some of the local repeaters....DAN
I have a frequency that keeps coming in really good but I can't seem to reach them. So I'm thinking of getting a better antenna. I can Bing the repeater but I can't talk to anyone. Sometimes someone says they hear me but in the noise. Its the NY repeater at 146.6250 minus pl 94.8 KQ2H. Maybe you can get them. The antenna you made will it be better than my Radio Shack Discone I'm using. If it simple I would like to try if I can get parts locally. My email is ron222@embarqmail.com if you want to send a plan. Thanks Ron
Ron im not able to hit it from here....
