Hello all
I operate on the 220 mhz. For a base radio I use the TYT TH-9000 220MHz Mobile radio.
My base antenna is an isopole. The ispole is awesome omnidirectional antenna.
I run RG -213U coax to the antenna.
For mobile I use another TYT TH-9000 220MHz radio with a hustler mag mount antenna.
Although the TYT TH-9000 220MHz radios are capable of 50 watt output I find 25 watts to be more than adequate for city wide coverage on simplex.
Anyone else out there using 220 mhz?
