I know this is totally showing my ignorance but I'm really confused on this and need to ask the question....so a 100 Watt HF rig is connected to a power supply and apparently pulling 20 Amps off the power supply. What is the amperage being pulled off the 120V house circuit in which the PS is connected? How can I figure this out?
A quick and easy way (but not all that accurate, see the later comments) is this. Since power = current times volts you can make a quick in-your-head approximation. The radio is 20 amps at 12 volts. The question is how many amps from the 120 volt power supply for that radio. It's easy to see that 120 is ten times what 12 is. You could then take that 20 amps and divide by that ten to see that about 2 amps would be needed. You would need to divide here to get the same power output since 20 times 12 would equal 2 times 120.
Now the problems with that quick calculation. First off, that assumes that the power supply is 100% efficient, a very bad assumption. For our quick estimation it would be a good idea to assume a 50% efficiency so you can quickly double that 2 amps to 4 and be fairly safe in your guess on how much current is on the AC side.
Now you can be a great deal more accurate using several methods. The most accurate would be to use a calibrated meter on the AC line. The more accurate this meter is, the more accurate your readings would be (well DUH!!!).
You could also use math like others have shown, but you would need to know several factors for those calculations to be accurate. These would include the current draws, the voltages, the efficiency of the power supply and probably several others. The current draws may vary depending on what the radio is doing (you should probably use the maximum values to be safe). The voltages are most likely approximate (that 12v is probably closer to 13.8v and 120v may be 118v or so for example).
The best thing is you really don't need all that accurate of an answer in most cases. So long as you over estimate the current draw and don't exceed the current on that circuit you should be fine with a reasonable estimate.
