Reviewed some posts but not finding what I need and this was difficult to find the right forum to post in since it covers alot, I figure you HAMs are the pros so here goes my situation.
I been SWL and Scanners off and on for a long time I enjoy HF alot and never had a proper antenna up due to some kind limitation. I will soon join in and be a Ham myself so now I m revisiting the issue of RFI/Noise floor and I want better. The issue: I have always been playing with a noise floor of about -80db to -90db in SWL I do my best and deal, I do okay but always had trouble getting those weaker ones in. I watch videos of others enjoying -100 to -120db and then again I see others where I am at more or less so I am unsure where I stand.
Is there really anything I can do to improve the noise floor for me?. Im not knowledgeable yet like most in radio so I can use some help I will continue my living situation,what I know and done so far.
Situation:
I live in north Texas near OK small town but decent size, old house and I mean old, old wiring, all is still two prong outlets. I have now a temp long wire outside my window to shack about 10ft up about 45' for HF. I had higher wideband & HF up at 25ft with no major difference. I am in process of ordering items & redoing all antennas and experimenting since I hope to also TX in a few months, but I am very limited in antenna location and config so trying to be creative.
What I know:
My house atm is not electrically grounded to the rod. Yeah I know I just felt you all slap your hands to your foreheads. I just discovered this and will have it shined up and new connector put on looks like the connector got old, corroded and broke off. Not sure if this will help my problem but needs to be fixed.
What I done:
In a effort to see if anything in the house is doing me harm I used a portable radio on AM on no station to see if I can get buzzing from areas of the house. I discovered a desk lamp which caused some RFI and its gone, LCD monitors in the shack some but cant change that. Router/Wifi but cant change that. They are causing some RFI but not effectng the noise floor that I can see. As far as I can tell I cant find much else with this method. I have RFI that I can see on my SDR displays that maybe external but we all get that on HF just not sure how bad it is for me.
Grounding plans:
On top of fixing the house ground to rod, I plan to have a electrician properly at least ground my shack in the house with true ground and 3 prong outlets as well and possibly a rod outside the shack and bring in ground thru the wall for a ground bar for equipment grounding.
Thats about it, not sure if I can improve things, it maybe just current conditions just dont have enough experience to tell.
Any help and advice appreciated.
Situation:
What I know:
What I done:
Grounding plans:
