Hello all,
I've been playing around with Radio Mobile for years to generate coverage maps. I don't think I'm doing everything just quite right though. I know radio coverage can never be 100% guaranteed per-se, however, I've been tinkering around with the software tonight. So, I went ahead and added my base, mobile and portables to the system I am working on and inputted all values including coax line loss, antenna gain (if any, or negative in this case for portables), antenna height, etc...
Here's the thing, I can make these maps lie like you wouldn't believe exaggerating coverage where coverage isn't at or I can make them so tight that it doesn't display coverage where coverage is at. I understand that coverage maps are estimates and cannot predict exact coverage due to atmospheric conditions amongst several other variables.
Here's what I need to know: I want to try and get a generally accurate coverage map for my base radio system.
When I am in the network window, I can select the following modes of variability: spot, accidental, mobile and broadcast and adjust percentages such as time, location and situations. Then, when it comes to generating the coverage map, I can adjust the thresholds for the map coverage depending upon the method used to calculate the map: S-Unit, dBm, uV, dBuV/m.
I've went ahead and made some maps and did field testing to compare. Some were a little exaggerated while others were too tight. What are some good settings to get a general day-to-day idea of coverage? I'm having a hard time deciphering the dBm also. I want to be able to hear radio traffic on portables. Doesn't have to be clear, but I don't want it being practically all noise to the point where I have to put headphones on to understand what the person is saying either in a fringe zone. What is a good "usable signal strength" value in dBm or otherwise? Furthermore, what are good values to select for modes of variability and the percentages therof.
Thanks,
Nick
Thanks,
Nick
