Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > AOR Receivers
AOR Receivers - A forum for the discussion of all AOR scanning radios and receivers.
Old 11-01-2014, 11:27 AM
NESN's Avatar
Default AR-2515
Saw an online ad for a AR-2515 for $35.00. Has the power cord but that's about it. The guy says he wants to sell it cause he can't figure it out.
I have zero experience with AOR scanners but I thought this might be good for shortwave listening. I remember back in the late 80's early 90's hearing that AOR scanners were a bear to program, but were the bomb for listening.
OK, is this a good price without the programming disks or any other accessories? Is this even worth it with all the newer gear out there now? Will I be able to program it without the software or is there somewhere I might find it?
Any thoughts or experiences would be appreciated.
Old 11-01-2014, 5:48 PM
dkf435's Avatar
The AR-2515 does not have a RS-232 interface the rear header was for a box that communicated with the CPU and had the interface in it. Your best bet is if you wanted an AOR with a RS232 interface is to get a AR-3000 or newer.
David Kb7uns
AR3000,5000,8000,8200,8600,SDU5000,5500,ARD25R1,10 ,20,71,72,75,7000,7100,8500,PC/R100,1000,2500 PSR500,600,800,PRO668,2035,96,106,BC760,796,996T,9 96XT,396T,396XT,HP1,HP2,436HP,536HP,WH-TRX1
Old 11-01-2014, 6:04 PM
dkf435's Avatar
Found the ad, does not look bad old 2002 upgraded to the 2515. I would grab it for listening but unless you have the BFO-1 you will not have SSB receive.
The AC adapter is worth $20
David Kb7uns
Old 12-31-2017, 10:01 AM
Default Correction
"The AR-2515 does not have a RS-232 interface the rear header was for a box that communicated with the CPU and had the interface in it."
The above statement from another user of this thread is incorrect.
In fact, the header connector at the rear panel of the AR-2515 receiver is standard RS-232. The original cable as supplied by ACE Communications was a straight through ribbon cable and header connector for the receiver end and a standard DB-25 for the PC end.
Any Terminal type program can be used to communicate with the receiver. No additional black box "interface" is required.
The AR-2515 receiver and the PC communicate asynchronously via an RS-232C interface at 300, 1200, or 9600 baud, with 8 Data Bits, No Parity, and 1 Stop Bit.
The signals used are as follows:
SIGNAL PIN
TRANSMITTED DATA(TXD) 2
RECEIVED DATA(RXD) 3
CLEAR TO SEND (CTS) 5
SIGNAL GROUND 7
Where:
TXD - Data transfer path from PC to AR-2515 receiver
RXD - Data transfer path from AR-2515 receiver to PC
CTS - Data enabling signal line from AR-2515 receiver to PC.
Old 12-31-2017, 9:37 PM
dkf435's Avatar
Well that information on the AR2515 was on the Javiation AOR UK site years ago, had no reason to believe it to be wrong, I wonder what else ACE did on the inside to make their AR2515 have RS232 and the UK model did not?.
All my early AR3000 radios along with the software, interface cables came from the $300 at the time, Gary Gesmundo wrote the software.
David
Old 01-01-2018, 1:41 PM
MrRadio's Avatar
I purchased a new AR-2515 around 1989.
It was pretty slick and scanned (for it's time) very fast. I think up to 100cps. I wasn't crazy about the bank setup though it was better than the 4 banks of 100 channels in the AR-3000.
I ended up returning it though, as for some reason it would not always receive several local PD UHF freqs (tower less than 10 miles away) that all my other scanners did.
Never got to the point of trying the software.
IIRC, I think I paid $795.00 and about $30 for the BFO-1
Dave D.
(Former 911 dispatcher)
Unication G5, BCD325p2, BCD396T, BC796Dx2, BC780XLTx2, AOR AR8000, RS Pro-26
Pro-2042/Opto535/Probe, Pro-2006/Opto456/Probe, Pro-2066, BC9000XLTx2
Old 01-01-2018, 7:54 PM
MrRadio's Avatar
Looking back in my books, I found a couple corrections.
The scan speed was 36 channels per second and I paid $695.00.
Dave D.
Old 01-02-2018, 2:09 AM
dkf435's Avatar
Found a copy of the AR-2515 manual and it had an addendum at the back from ACE detailing the commands and the protocol and how the radio sorted the frequencies to help speed scanning so it was a work in progress
I got the first AR3000 around 1992-1993 and it was about $950 shipped along with the software for $300 and the software was so simple but you could do sweeps and it would log time and hits and the control cable would enable the recorder to record and Gesmundo later came out with a ctcss tone and dtmf decoder that worked off the parallel port and it would log everything and print it out.
David
