MStep
It took me some time to figure it out, but it does work very well and it is quite versatile. Unfortunately, AOR left the final instruction out of the Operating Manual to initiate frequency offset. Once you have set the amount of your offset, in order to quickly monitor the offset frequency, you simply press the MONI button.
For example, if you have a +3 mhz offset programmed into Offset 1, you simply program any channel in any bank of the radio that requires a +3 mhz offset to Offset 1, and when you hit the MONI button, you will go to the offset frequency for as long as you hold the MONI button.
In addition, for each channel which has an offset assigned to it, the indicator "DUP" appears on the lower left hand side of the display. For channels with no frequency offset assigned to them, the MONI button just "breaks the squelch" for that particular channel.
The manual is very nicely printed and illustrated, but I've noticed on several occasions, like above, they fail to fully explain the final step(s) needed to initiate a function.
Hopefully, over the next several weeks, as I have more time to explore the radio and the manual, I'll be able to compile other "Tricks & Tips" that may have been overlooked in the manual.
And please feel free to add you own discoveries to this thread.
