MStep
AOR has posted a new firmware update for the DV1 receiver. Specifications as follows:
AR-DV1 FIRMWARE UPDATE v1602A RELEASE NOTES
(c)2016 AOR, LTD.
April 19, 2016
This update will correct issues that some customers experienced, it also adds more functionality to the AR-DV1. AOR is committed to the continuous improvement of its products and will post firmware updates periodically to further extend the capabilities of this receiver.
IMPORTANT!
This firmware update will clear all your channel, bank and configuration memory data. It is therefore advised to make a backup on SD card as described chapter 5-2 of the user manual, and to restore this data after the firmware update.
Following bugs have been removed:
-SCAN sometimes stopping after a couple of minutes.
-After using TIMER/ALARM function with SQL open, it stayed open even after ending the function.
-SCAN/SEARCH GROUP last-one memory data not saved when shutting receiver off.
(c)2016 AOR, LTD.
April 19, 2016
IMPORTANT!
