Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > AOR Receivers
AOR Receivers - A forum for the discussion of all AOR scanning radios and receivers.
  #41 (permalink)
Old 04-01-2017, 12:11 AM
Originally Posted by MStep View Post
This will give the AOR DV1 the decided advantage for those interested in digital monitoring.
Dream on. Those of us who aren't hams need trunking.
  #42 (permalink)
Old 09-07-2017, 11:55 PM
bwinking's Avatar
When I saw the DV1 it reminded me of the AOR ar2500, as an after thought they put a piece of tin foil under the top as shielding, it was suppose to be stuck to the inside top of the case, after a few days with temperatures in the mid 80's the 1st summer, is probably when it came loose and was laying on top of the circuit board, not a good way for heat to dissipate, it had all kinds of issues, and the 1990 or 91 price was $500. , imagine that......, I made a promise to myself to not buy anything from aor ever again.
As the ar2500 scanned vhf it made popping / crackling noises, still have it sitting in a closet someplace., Aor should of been selling it for $49. in the USA, at $500. in 1991 dollars it should have worked flawlessly, just a few years earlier that's close to what a Yaesu 757 GX was selling for, when the GX II came out. I'd rate the ar2500 as a worst radio contender.
  #43 (permalink)
Old 09-08-2017, 10:01 AM
RFI-EMI-GUY's Avatar
Was the Regency MX3000 an AOR product? It appeared similar. I had one if those as an early wide band scanner. It had a ton of birdies and radiated gobs of them from its case. I put aluminum tape inside the case to constrain the noise. It did work with an external antenna wish I oreamp and I logged many Milsat and ATS3 satellite ckmmunications. I bought a brand new Icom R7000 to replace it. Night and day difference.
"Have Spectrum Analyzer, - Will travel" "Going Green"
