RELEASE NOTES
(c)2017 AOR, LTD.
Feb.20, 2017
This update will correct issues that some customers experienced, it also adds more functionality to the AR-DV1.
AOR is committed to the continuous improvement of its products and will post firmware updates periodically to further extend the capabilities of this receiver.
IMPORTANT!
This firmware update will clear all your channel, bank and configuration memory data. It is therefore advised to make a backup on SD card as described chapter 5-2 of the user manual, and to restore this data after the firmware update.
The following bugs have been fixed:
- CTCSS and DCS frequencies did not appear in (Digital) AUTO mode.
- Wav recordings on SD: Approx. every minute, 300ms of audio was missing from the data.
- D-STAR signal information stayed sometimes on display even though frequency has been changed.
- D-STAR would sometimes decode only when frequency set 2kHz up.
The following features have been improved:
- Wav recordings on SD now with less background noise.
The following features have been added:
- Added support for “reverse tone” squelch in CTCSS. To enable this feature, F+1 then turn the dial until [RTN] appears and validate with ENT. The frequency of the reverse tone is set in CTCSS parameters. The reverse tone squelch is a function to mute (close) the squelch only when AR-DV1 receives a frequency matching the programmed tone frequency. It unmutes (opens) the squelch when it receives a frequency which is not the programmed tone frequency. This function is not generally used in ham radio operation, but rather by some taxi and bus drivers.
-“Reverse tone” argument added for the tone squelch command “CI”. The argument is n=2.
- D-CR user code now displayed.
AR-DV1 Firmware 1702D | Firmware Updates | Download Area | Support | AOR U.S.A., INC. Authority On Radio Communications
Test in progress
(c)2017 AOR, LTD.
Feb.20, 2017
IMPORTANT!
Test in progress
