Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > AOR Receivers
AOR Receivers - A forum for the discussion of all AOR scanning radios and receivers.
Old 04-13-2017, 7:48 AM
Default Aor dv1 setup help and dmr help pls
Hi I've just bought a aor dv1 receiver so I can listen to digital
Has anyone who owns got any tips for setting up scanner for dmr
And can you receive shopwatch thanks for any help
Old 04-13-2017, 8:05 AM
MStep's Avatar
I've found that in order to scan DMR channels with the most efficiency, I program my DMR channels in either one or more scan banks and try to segregate them as much as possible from my analog channels. It's also a good idea to to get program each channel as DMR as opposed to "Auto". Although you can scan DMR specific channels with the squelch set to zero, you can effectively increase your scan rate by moving the squelch up to a level where the scan speed increases without losing the ability to stop on a busy channel.
Bottom line is that you have to do a bit of experimentation with the unit to find your operational comfort level.
Old 04-13-2017, 8:14 AM
Thanks very much for advice it's appreciated
Old 04-18-2017, 5:18 PM
I found that for each digital mode, it will miss the first channel as it scans. So I enter the first channel twice and group all the modes together.
Old 04-19-2017, 1:41 AM
F5HPE's Avatar
Thumbs up DV1's quick grip
Did you "Pass" it for scan mode?
If you need to descover easily your brand new DV1, may I recommend you to have a look to my DV1 Manager software?
Le site du DV1 Manager
This software is entended to help you to get a quick grip of your receiver.
This software is supported by AOR.
Perhaps it will help you to get more about DV1 facilities?
Enjoy your DV1
