AlphaFive
Referring to the DV 1, although I see the coverage is listed as 100 KHz. to 1300 Mhz, are there coverage breaks? Specifically, most, not all, scanner radios will stop at 54.00 and pick back up in the 70's or at 108 Mhz. Will this receiver go through 54.00 to 108.000 Mhz.? I cannot locate anything that says there are breaks in the band coverage.
If so, kudo's to the DV 1. Thanks for your help, Lance
I'm aware of the cellular breaks, not an issue..
