Go Back   The Forums > Scanners, Receivers and Related Equipment Forums > AOR Receivers
AOR Receivers - A forum for the discussion of all AOR scanning radios and receivers.
Old 07-18-2017, 5:44 AM
Default AR 3000A
Hi everyone I was wondering if anyone can help me. I got my receiver out f mothballs last night and it worked perfectly . I have switched it on again this morning and nothing. Internal fuse ok. Is there any where I can get it repaired it sounds like there is something loose inside , to my knowledge it has never been dropped since I got it.
Old 07-18-2017, 6:37 AM
G7HID's Avatar
Waters & Stanton, the UK AOR agent can be contacted here:
Waters & Stanton
Call: 01702 204965 or 01702 206835
Address: Unit 1 Fitzherbert Spur, Farlington, Portsmouth, Hampshire, PO6 1TT
Connect Systems CS750 and CS800, Hytera PD-365, Motorola DP4600.
Raspberry Pi 2 and DV4Mini HotSpot
AOR AR-DV1 Digital Voice Receiver / eSPY on ARD
WS1088 / TRX-1 / Whistler Q / UBCD3600XLT..
Old 07-18-2017, 8:46 AM
Default 3000A
There is a reasonable chance it is the backup battery.
Do a Google search about it. You should also look for information on the RESET button. To get to it you need to remove the top cover, and remember the loudspeaker wires are attached.
There was more than one revision of the AR3000A boards, so I cannot pinpoint where the switch is on yours, but it is all documented on the Net if you look.
If it is the battery, resetting will bring the Radio back to life as a temporary measure, then the battery will need to be replaced. At least you will know if that is all that needs doing.
Old 07-18-2017, 11:04 AM
Thankyou for replies.
All information here is Copyright 2012 by LLC and Lindsay C. Blanton III.Ad Management by RedTyger
Copyright 2015 by LLC Privacy Policy  |  Terms and Conditions
