Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > AOR Receivers
AOR Receivers - A forum for the discussion of all AOR scanning radios and receivers.
Old 01-03-2018, 2:12 AM
Default AR-DV1 Selectivity?
While looking at the DV1's brochure, I noticed that AOR doesn't list the selectivity for this receiver. Are those figures advertised somewhere? And if not, then why is AOR not listing them?
Old 01-03-2018, 10:46 AM
harryshute's Avatar
Also in owners manual only lists sensitivity.
Scanning since before scanners
Old 02-02-2018, 3:36 PM
Does anyone with a DV1 care to compare it's selectivity to other receivers they own so as to give us some kind of baseline?
Thanks!
Old 02-03-2018, 4:44 AM
F5HPE's Avatar
Which kind of others receviers you want to compare with?
Better to compare SDR vs SDR. Isn't it?
F5HPE - TU7MM - JJ1HKT - KN4HKM
Author of "DV1 Manager" and "DV10 Manager" software for AR DV1 and AR DV10
Old 02-03-2018, 3:32 PM
Well, whatever anyone with a DV1 has to compare. It would at least give one a ballpark idea of the DV1's capabilities. Compare it to the AOR 8200 or the R20, anything that has specs publicly available.
Old 02-04-2018, 12:25 PM
F5HPE's Avatar
So, better not to compromise yourself by compariring a desktop digital SDR like DV1 with an portable analog radio as 8200.
The only thing you coul compare is frequency range and sensitivity. All other features are Digital mode that 8200 can't decode except P25.
Don't you think?
Old 02-04-2018, 2:36 PM
Yes. That's a good point you bring up.
