MStep
The AOR firmware update page for the DV1 states:
"For USA customers with serial numbers starting with 09560xxx kindly ask to info@aorusa.com which firmware extension you should use."
I wrote to Taka at AOR and received this reply:
"Please try updating with DV2 firmware.
But since DV1 will usually detect the compatible firmware type, if DV2 does not work try using DV1."
I wrote back to Taka:
"That sounds a little scary. I don't want to "brick" the radio. My DV1 receiver does not "see" the firmware with the .DV2 extension on the card. There are two options--- one would be to use the .DV1 firmware, and the other would be to change the .DV2 to .DV1 --- is there any reason why it cannot be determined which is the correct version for the USA customers with serial numbers starting with 09560xxx ?"
So the question is, has anyone with the U.S. version of the DV1 receiver done the 1805A firmware upgrade. Which version did you use and did it work?
