Hello
All will be well soon - all things are noted by AOR, all things are being worked on by AOR.
As I have stated they may not be able to respond to everything to everyone, but all things are on their lists being worked through very diligently.
Yes, it's annoying - many have reported some improvements at various levels with each update , maybe not ALL things yet, but it will happen.
After all these firmware issues are addressed and if issues still persist and something is way out of wack they will address that too.
If you look at the Uniden SDS100 they have and are going through many issues also. Yes, they have Upman from Uniden on the forums giving feedback where needed, and several updates, but give the DV10 users some more time as the unit is only getting out into the mass market in volume as I write this and AOR some time to work through everything. 3 firmware in 3 months is not bad guys given the complexity of the unit. I know, it's not ideal, I know things might have been different, but we can not look back, we can only move forward.
Patience is the key - I know it's never fun when all are eager to use the device.
