In Phoenix, AZ, and using the HP-1(E):
In my primary FL (Home 1), I observed that I had the APS System programmed in previously. It has probably been in the scanner more than three years. I renamed the System APS (OLD). This old APS System only had one (1) Department (APS). This Department (APS) has three (3) Channels. They are APS Field Operations, APS Field Operations, and APS Transmission Maintenance. I set all 3 channels to Avoid Off. This System is showing 28 Sites. I avoided all except the three (3) named Aguila (Maricopa), Oatman Mountain (Maricopa), and Shaw Butte (Maricopa).
I then created a new APS System in the same FL (Home 1), and named it APS (NEW)1. This was using the HP DB that was in the scanner. It might be be "outdated" by several months. This new System has four (4) Departments. I avoided 3 of these departments, "Arizona Division of Emergency Management", Arizona State Agencies, and Miscellaneous. This leaves department APS, which is showing Nineteen (19) Channels. I avoided all except #2 APS Field Operations, #3 APS Field Operations, and #4 APS Transmission Maintenance. This System is also showing 28 Sites. I again avoided all except the three (3) named Aguila (Maricopa), Oatman Mountain (Maricopa), and Shaw Butte (Maricopa).
At this time I updated the HP DB. I then created a new APS System in the same FL (Home 1), and named it APS (NEW)2. This was using the HP DB that was just updated. This new System has four (4) Departments. I avoided 3 of these departments, "Arizona Division of Emergency Management", Arizona State Agencies, and Miscellaneous. This leaves department APS, which is showing Nineteen (19) Channels. I again avoided all except #2 APS Field Operations, #3 APS Field Operations, and #4 APS Transmission Maintenance. This System is also showing 28 Sites. I again avoided all except the three (3) named Aguila (Maricopa), Oatman Mountain (Maricopa), and Shaw Butte (Maricopa).
I set Sentinel to upload to the HP-1(E). I set the scanner to scan only FL (Home 1), Systems APS (OLD), APS (NEW)1, and APS (NEW)2. As the scanner began scanning, right away I noticed something unusual. The scanner is spending right at one (1) second on each System. This is a lot faster than usual. I suppose that this is due to all of the TGs being Analog?
Using the Analysis function of the HP-1 (E), and analyzing the three (3) Sites being used for all three System scans, I determined that I am receiving a signal only from the Shaw Butte Site. I now have avoided all Sites but the Shaw Butte Site. I am located near I-17 and Greenway and the signal off of Shaw Butte is very strong (8.5/10) and of maximum quality (100%). However, activity is shown as basically non-existent.
It is about midnight, lol. I'll listen to this configuration for a few days and report on any activity heard.
