Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Arizona Radio Discussion Forum
Arizona Radio Discussion Forum - Forum for discussing Radio Information in the State of Arizona.
Old 04-29-2017, 7:48 AM
WB2UZR's Avatar
Default Maricopa County ProScan Feed
Hi all:
Does anyone run, or know who runs the Maricopa county feed that is listed on the ProScan client? It has been unreachable for quite a long time, and I'm wondering if there is a problem, or maybe it's a private feed. It is listed as Maricopa county, and "general scanner channels"
Scott/WB2UZR
Old 04-29-2017, 9:48 AM
eaf1956's Avatar
Originally Posted by WB2UZR View Post
Hi all:
Scott/WB2UZR
If it was a private feed it wouldn't be listed!
Current scanners:BCD 996XT,BCD996P2
BCD536HP (2) and a SDS 100
Ham Gear: Icom 7000, U82, V82, V8, IC 2820, MD2017, Vertex Standard EVX 539, MD 9600, CS 800D, Yaesu FTM100 DR and a YAESU FTM400DR
Old 05-01-2017, 9:45 PM
ICP963's Avatar
Hi all:
Scott/WB2UZR
That is probably mine. It is up sometimes, but not always. It is up at the moment.
Roy Schahrer ICP963
e-mail k8x815@cox.net
Old 05-01-2017, 9:51 PM
WB2UZR's Avatar
Thanks, I see it there, but FYI, it's not reachable. Not sure what the issue is, I can connect to other feeds fine. I dropped an email to Bob from ProScan a few months back, and he wasn't sure what was up, maybe an IP address change?
Thanks!
Old 05-02-2017, 9:12 AM
mule1075's Avatar
Unreachable for me as well and has been for sometime.
Sent from my SM-S907VL using Tapatalk
Uniden BCD536HPx2/250D Motorola HT1000/GM360
Old 05-02-2017, 6:34 PM
ProScan's Avatar
It may appear up but is it up to the outside world? Check the router port forwarding with port of server and use TCP.
