Hi is there anything about Tempe PD I need to know? I have tried for hours to get this to work It is SUPPOSED to be a P25 system on the RWC system. Anyone know what I am missing here?
Make sure you have Simulcast F enabled and are able to receive from your location. Tempe PD talkgroups are currently only carried on this site. Tempe is quite active on talkgroups 2601 A2 North and 2603 A4 South of the RWC.
Which CC's are you using? I have both Simulcast C & F for my control channels and hear them quite frequently.
Out of curiosity, what kind of radio?
Assuming that your scanner is programmed correctly, the problem may be the LSM, or Linear Simulcast Modulation, that the RWC (and TOPAZ RWC) utilizes.
Each of the Simulcasts has multiple transmitter locations, which can cause multi-path interference. This essentially cancels out the digital signal in our scanners, because they don't have the same circuitry that commercial grade two-way radios do to handle it.
One potential fix, at least for a base scanner at home, is to buy a directional antenna, and experiment with which direction to point it in. (Pointing it at the closest tower site isn't always the best direction.)
A second fix would be to purchase a Unication G4 or G5 P25 pager, which has a commercial grade receiver that handles LSM systems such as the RWC and the TOPAZ RWC.
Good luck.
John
Peoria
I have a GRE PSR-500, and am unable to receive Simulcast G, which covers the West Valley, or Simulcasts A & B which cover the City of Phoenix.
Yes, it's programmed properly. It just can't handle the LSM issues.
I am fortunate however, in that Peoria PD can be heard on the White Tanks and Towers Mtn IR sites, and is receivable most of the time. Surprise PD is also carried on the White Tanks IR.
I cannot, however, listen to Glendale PD, El Mirage PD, or Tolleson, Avondale or Goodyear PD's.
By listening to the Thompson Peak IR, I can hear Phoenix PD's Black Mtn 200 precinct in far north Phoenix, but I can't hear the Cactus Park 900 precinct or the Maryvale/Estrella 800/300 precinct on either Simulcast A or G, where they're carried.
On occasion, I can hear Phoenix FD's K-1 and K-6 off of the Towers Mtn IR, and I can hear K-2 off of either the White Tanks or Thompson Peak IR's, but most of my listening to the FD is limited to the analog VHF channels. I'd really like to be able to hear K-10 through K-15, because they're the most exciting K-decks to listen to, with the mountain rescues and major motor vehicle accidents.
John
Peoria
