Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Arizona Radio Discussion Forum
Arizona Radio Discussion Forum - Forum for discussing Radio Information in the State of Arizona.
Old 12-31-2017, 10:21 AM
Vikefanz's Avatar
Default Help needed P25 system
I have a BCD996P2 scanner and have used RR to gather frequencies for Cochise county AZ. I manually entered in to freescan to upload and am able to hear everything except Sierra Vista PD. I created a P25 system and put in all control channels but I hear nothing. I am located in sierra vista and am willing to bring the scanner to someone that could help program it. Please help and thank you.
Old 12-31-2017, 10:34 AM
troymail's Avatar
This system?
https://www.radioreference.com/apps/db/?sid=9165
I don't recall how the 996 scans the (5?) sites but a couple of thoughts/suggestions-
Given the limited amount of information in the RRDB, you probably want to try using "ID Search" vs. "ID Scan" (assuming your aren't already doing that).
There is a "simulcast" site and 4 "other" sites. If your scanner is trying to scan one of the smaller sites, the talkgroup(s) of interest may not be carried on that site. You'll want to try to scan the simulcast site if at all possible (most likely to carry the largest number of talkgroups) and also try to scan the other sites (control channels) as well if they are in range.
There appears to be lots of unknowns with this system based on the lack of data....
And then there is always the possibility encryption is in use.... but that's just speculation on my part.
Unication G5(UHF)
Old 12-31-2017, 10:45 AM
Vikefanz's Avatar
So are you saying to just enter the frequency for the simulcast site? I even checked radio intercept site and they had control numbers in the 770. Range which I entered as well with no luck. Thanks for your help.
Old 12-31-2017, 10:54 AM
troymail's Avatar
Given the available info, I'd focus on the simulcast site and the frequencies assigned:
769.28125
769.53125
769.76875
Ignore the rest for now.
Use "ID Search" vs. the default "ID Scan".
Unication G5(UHF)
Old 12-31-2017, 11:06 AM
troymail's Avatar
Keep in mind this note posted with the system:
System appears to be almost complete. It is not yet operational with voice communications.
However, the last update appears to have been more than 3 months ago.....
Unication G5(UHF)
Old 12-31-2017, 11:12 AM
Vikefanz's Avatar
I tried this and on the display screen now it does not show any control channel it shows NFM?
Old 12-31-2017, 11:21 AM
Vikefanz's Avatar
I have seen previous posts about people here in Sierra Vista finding the SV pd by using Talkgroups 1301 but how do you program by Talkgroups? Thank you for trying to help I really appreciate it.
Old 12-31-2017, 11:27 AM
troymail's Avatar
ok - based on the available data, try/check/add these...
769.56875
769.78125
771.49375
Unication G5(UHF)
Old 12-31-2017, 11:34 AM
troymail's Avatar
BTW - you may want to click on the red and white triangle in the upper righthand corner and ask to have this moved to the Arizona forum to get more local visibility and assistance.
Unication G5(UHF)
Old 12-31-2017, 11:46 AM
Vikefanz's Avatar
Ok I added these and the display shows the first channel but hear nothing
Old 01-01-2018, 5:08 PM
FLANO's Avatar
AZ DB Administrator
Ok, just a couple of things:
I removed the note about the system. It is in full-time use by CCSO and SVPD.
You can hear SVPD on any site. I've driven all over this county, you will hear them.
I am seeing SVPD and CCSO right now on the Texas Canyon site.
The primary talkgroups in use are:
1001 for CCSO
1301 for SVPD.
I have picked up a couple of other TGs that I have not been able to as of yet confirm what the talkgroups are being used for by each department. Keep in mind I am in Pima County, so this is not my primary listen, but I occasionally check it out via DSD+ -
CCSO
1002
1003 - 54 hits on this one
1004
1006
1007
SVPD
1302
1303 - 17 hits on this one
1304
1305
I do not use the scanner that you have, but I'm guessing that you should have the ability to download the database entry for this system into your scanner from RadioReference, which would then correctly program your scanner for listening
Try this link to help you with creating Talkgroups for your radio, if you are going the manual entry route.
http://marksscanners.com/996xt/996xt.shtml
Hope this helps,
John
SE of Tucson
Old 01-01-2018, 5:52 PM
Vikefanz's Avatar
Thank you John, I did import directly from RR and was eventually able to figure out the problem; the squelch was too high. I have been listening to both both Talkgroups now.
Old 01-01-2018, 5:58 PM
FLANO's Avatar
AZ DB Administrator
Fantastic !
John
SE of Tucson
