Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Arizona Radio Discussion Forum
Arizona Radio Discussion Forum - Forum for discussing Radio Information in the State of Arizona.
Old 01-28-2018, 11:32 PM
Question Bullhead City Fire Department?
Has BHCFD changed frequencies? I noticed in the DB their frequency now says depreciated, and it's been a while since I've heard anything on that frequency. I don't think i've heard anything on the Fort Mohave/Mohave Valley dispatch frequency either in a while. I am in Kingman, but usually I can receive Bullhead FD, as well as Mohave valley, and Fort Mohave FD fine. I am still getting BHCPD fine.
Old 01-29-2018, 12:58 AM
Go back to the database. Look 9 entries down from the deprecated entry.
153.935.
John
Peoria
Old 01-29-2018, 2:06 AM
Try 154.415
Old 01-29-2018, 2:54 AM
153.935.
John
Peoria
I already have that frequency. That is the frequency that is supposed to be used by Fort Mohave and Mohave Valley FD's which are dispatched by BHCFD.
Old 01-29-2018, 2:57 AM
Originally Posted by bubbablitz View Post
Try 154.415
I will try that frequency.
Old 01-29-2018, 11:18 PM
Today I have confirmed that I am still hearing that frequency. It is still being used to dispatch MVFD, and FMFD. Still have not heard anything from BHCFD. I guess I'll just figure it out whenever I go down there.
Old 01-29-2018, 11:25 PM
154.415 tone 100.0
Old 01-29-2018, 11:40 PM
- 151.380000 NFM CTCSS 74.4Hz Custom 1 Off 2sec Off Off 0 None Off
- 151.520000 NFM CTCSS 146.2Hz Custom 1 Off 2sec Off Off +3 None Off
- 151.880000 NFM DCS 131 Custom 1 Off 2sec Off Off 0 None Off
- 152.480000 NFM CTCSS 159.8Hz Custom 1 Off 2sec Off Off 0 None Off
- 153.935000 NFM CTCSS 186.2Hz Custom 1 Off 2sec Off Off 0 None Off
- 154.115000 NFM CTCSS 127.3Hz Custom 1 Off 2sec Off Off 0 None Off
- 154.415000 NFM CTCSS 100.0Hz Custom 1 Off 2sec Off Off +3 None Off
- 154.430000 NFM CTCSS 100.0Hz Custom 1 Off 2sec Off Off 0 None Off
- 154.602500 NFM DCS 131 Custom 1 Off 2sec Off Off 0 None Off
- 154.725000 NFM CTCSS 173.8Hz Custom 1 Off 2sec Off Off +3 None Off
- 154.745000 NFM CTCSS 206.5Hz Custom 1 Off 2sec Off Off 0 None Off
- 154.747500 NFM CTCSS 206.5Hz Custom 1 Off 2sec Off Off 0 None Off
- 154.750000 NFM CTCSS 206.5Hz Custom 1 Off 2sec Off Off 0 None Off
- 155.040000 NFM CTCSS 186.2Hz Custom 1 Off 2sec Off Off 0 None Off
- 155.055000 NFM CTCSS 114.8Hz Custom 1 Off 2sec Off Off 0 None Off
- 155.070000 NFM CTCSS 156.7Hz Custom 1 Off 2sec Off Off 0 None Off
- 155.115000 NFM CTCSS 167.9Hz Custom 1 Off 2sec Off Off +3 None Off
- 155.160000 NFM CTCSS 151.4Hz Custom 1 Off 2sec Off Off 0 None Off
- 155.210000 NFM CTCSS 179.9Hz Custom 1 Off 2sec Off Off 0 None Off
- 155.490000 NFM NAC 70A Custom 1 Off 2sec Off Off 0 None Off
- 155.640000 NFM CTCSS 192.8Hz Custom 1 Off 2sec Off Off 0 None Off
- 155.655000 NFM CTCSS 136.5Hz Custom 1 Off 2sec Off Off 0 None Off
- 155.700000 NFM NAC 70A Custom 1 Off 2sec Off Off 0 None Off
- 155.715000 NFM CTCSS 173.8Hz Custom 1 Off 2sec Off Off 0 None Off
- 156.150000 NFM CTCSS 173.8Hz Custom 1 Off 2sec Off Off 0 None Off
- 159.232500 NFM CTCSS 100.0Hz Custom 1 Off 2sec Off Off 0 None Off
- 162.237500 NFM CTCSS 123.0Hz Custom 1 Off 2sec Off Off 0 None Off
- 164.837500 NFM CTCSS 218.1Hz Custom 1 Off 2sec Off Off 0 None Off
- 166.750000 NFM CTCSS 100.0Hz Custom 1 Off 2sec Off Off 0 None Off
- 167.125000 NFM CTCSS 123.0Hz Custom 1 Off 2sec Off Off 0 None Off
- 169.987500 NFM CTCSS 110.9Hz Custom 1 Off 2sec Off Off 0 None Off
- 172.462500 NFM NAC 526 Custom 1 Off 2sec Off Off 0 None Off
Old 01-29-2018, 11:41 PM
just a few freq captures from area
Old 01-31-2018, 12:14 AM
radioprescott's Avatar
Some of the captured CTCSS do not match the database:
153.935000 capture=186.2Hz DB=151.4 PL freq=BCFD-Dispat
154.115000 capture=127.3Hz DB=173.8 PL freq=BCPD-ANIM CT
154.415000 capture=100.0Hz DB=173.8 PL freq=BCFD-SIM/RPT
154.430000 capture=100.0Hz DB=173.8 PL freq=Tactical - Oatman Simplex*
If he's programming a CTCSS, maybe that's why the OP isn't hearing it?
John
If you can't fix it with a hammer, you've got an electrical problem.
Old 01-31-2018, 12:22 AM
I don't have any PL tones programmed in my scanner. My location is most likely the reason why i'm not hearing anything on 154.415. I am still hearing 153.935 which is Fort Mohave, and Mohave Valley fire dispatch.
Old 01-31-2018, 12:43 AM
they were found in discovery mode on the bcd436hp
Old 01-31-2018, 12:49 AM
captures are from mobil ops in laughlin, bhc , ft mohave , oatman areas mainly
Old 01-31-2018, 12:50 AM
thats just sample of changes and stuff thats still old tones in the area
Old 01-31-2018, 2:55 AM
Default Bull head FD
Try these freq s for Bull Head FD
154.8225-Bull head FD disp
154.0550-Bull head FD F-gnd-2
154.220-Bull head FD F-gnd-1
154.415-Bull head FD repeater
154.445-Bull head FD repeater
159.045-Bull head FD F-gnd-A
159.075-Bull head FD F-gnd-B
153.935-Bull head FD dips
Patrick VerVooren
E-mail patrick31365@verizon.net
Old 01-31-2018, 5:32 PM
activity that was on 154.8225 vanished and is now on 154.415 with tone 100.0
Old 01-31-2018, 5:35 PM
Thanks for the info.
Old 01-31-2018, 6:13 PM
admins seem to not place same freqs even if different tones and uses for those seperate tones,, treats them as 1 licence means one tone only often times
Old 01-31-2018, 6:42 PM
- 151.377500 NFM CTCSS 74.4Hz Custom 1 Off 2sec Off Off 0 None Off
Avoid 151.880000 NFM DCS 131 Custom 1 Off 2sec Off Off +3 None Off
- 151.925000 NFM CTCSS 110.9Hz Custom 1 Off 2sec Off Off +3 None Off
- 151.955000 NFM CTCSS 67.0Hz Custom 1 Off 2sec Off Off +3 None Off
- 152.237500 NFM CTCSS 159.8Hz Custom 1 Off 2sec Off Off 0 None Off
Avoid 152.480000 NFM CTCSS 254.1Hz Custom 1 Off 2sec Off Off 0 None Off
Avoid 152.480000 NFM CTCSS 159.8Hz Custom 1 Off 2sec Off Off 0 None Off
Avoid 152.481200 NFM CTCSS 159.8Hz Custom 1 Off 2sec Off Off 0 None Off
- 153.010000 NFM CTCSS 127.3Hz Custom 1 Off 2sec Off Off 0 None Off
Avoid 153.635000 NFM CTCSS 151.4Hz Custom 1 Off 2sec Off Off +3 None Off
- 153.935000 NFM CTCSS 186.2Hz Custom 1 Off 2sec Off Off +3 None On
- 154.055000 NFM DCS 703 Custom 1 Off 2sec Off Off +3 None Off
Avoid 154.112500 NFM CTCSS 127.3Hz Custom 1 Off 2sec Off Off +3 None Off
- 154.115000 NFM CTCSS 127.3Hz Custom 1 Off 2sec Off Off +3 None Off
- 154.130000 NFM CTCSS 173.8Hz Custom 1 Off 2sec Off Off +3 None Off
- 154.412500 NFM CTCSS 100.0Hz Custom 1 Off 2sec Off Off +3 None Off
- 154.415000 NFM CTCSS 100.0Hz Custom 1 Off 2sec Off Off +3 None On
- 154.445000 NFM CTCSS 173.8Hz Custom 1 Off 2sec Off Off 0 None Off
- 154.490000 NFM CTCSS 67.0Hz Custom 1 Off 2sec Off Off 0 None Off
Avoid 154.600000 NFM DCS 131 Custom 1 Off 2sec Off Off +3 None Off
Avoid 154.602500 NFM DCS 131 Custom 1 Off 2sec Off Off +3 None Off
Avoid 154.725000 NFM CTCSS 173.8Hz Custom 1 Off 2sec Off Off +3 None On
Avoid 154.745000 NFM CTCSS 206.5Hz Custom 1 Off 2sec Off Off 0 None Off
Avoid 154.747500 NFM CTCSS 206.5Hz Custom 1 Off 2sec Off Off 0 None Off
- 154.750000 NFM CTCSS 206.5Hz Custom 1 Off 2sec Off Off +3 None On
- 155.040000 NFM CTCSS 186.2Hz Custom 1 Off 2sec Off Off +3 None Off
- 155.055000 NFM CTCSS 114.8Hz Custom 1 Off 2sec Off Off +3 None Off
Avoid 155.068700 NFM CTCSS 156.7Hz Custom 1 Off 2sec Off Off +3 None Off
- 155.070000 NFM CTCSS 156.7Hz Custom 1 Off 2sec Off Off +3 None On
Avoid 155.112500 NFM CTCSS 167.9Hz Custom 1 Off 2sec Off Off +3 None Off
Avoid 155.115000 NFM CTCSS 167.9Hz Custom 1 Off 2sec Off Off +3 None Off
- 155.210000 NFM CTCSS 179.9Hz Custom 1 Off 2sec Off Off +3 None On
- 155.212500 NFM CTCSS 179.9Hz Custom 1 Off 2sec Off Off 0 None Off
Avoid 155.487500 NFM NAC 70A Custom 1 Off 2sec Off Off 0 None Off
- 155.490000 NFM NAC 70A Custom 1 Off 2sec Off Off +3 None On
Avoid 155.637500 NFM CTCSS 192.8Hz Custom 1 Off 2sec Off Off 0 None Off
- 155.640000 NFM CTCSS 192.8Hz Custom 1 Off 2sec Off Off +3 None On
- 155.655000 NFM CTCSS 136.5Hz Custom 1 Off 2sec Off Off +3 None Off
- 155.700000 NFM NAC 70A Custom 1 Off 2sec Off Off +3 None On
Avoid 155.712500 NFM CTCSS 173.8Hz Custom 1 Off 2sec Off Off +3 None Off
Avoid 155.715000 NFM CTCSS 173.8Hz Custom 1 Off 2sec Off Off +3 None On
- 155.790000 NFM CTCSS 173.8Hz Custom 1 Off 2sec Off Off 0 None Off
- 155.805000 NFM CTCSS 127.3Hz Custom 1 Off 2sec Off Off 0 None Off
- 155.880000 NFM DCS 165 Custom 1 Off 2sec Off Off +3 None Off
Avoid 156.150000 NFM CTCSS 173.8Hz Custom 1 Off 2sec Off Off +3 None Off
- 156.180000 NFM CTCSS 173.8Hz Custom 1 Off 2sec Off Off 0 None Off
Avoid 158.790000 NFM CTCSS 77.0Hz Custom 1 Off 2sec Off Off +3 None Off
Avoid 159.015000 NFM CTCSS 156.7Hz Custom 1 Off 2sec Off Off +3 None Off
Avoid 159.232500 NFM CTCSS 100.0Hz Custom 1 Off 2sec Off Off +3 None Off
- 159.322500 NFM CTCSS 107.2Hz Custom 1 Off 2sec Off Off 0 None Off
- 164.572500 NFM NAC 4CE Custom 1 Off 2sec Off Off 0 None Off
- 164.575000 NFM NAC 4CE Custom 1 Off 2sec Off Off +3 None Off
- 167.125000 NFM CTCSS 123.0Hz Custom 1 Off 2sec Off Off +3 None Off
- 169.360000 NFM CTCSS 192.8Hz Custom 1 Off 2sec Off Off 0 None Off
Old 01-31-2018, 11:43 PM
bore freq grabs
