Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Arizona Radio Discussion Forum
Arizona Radio Discussion Forum - Forum for discussing Radio Information in the State of Arizona.
Old 10-07-2018, 5:21 PM
Default Radio Shack Pro 96
I have a Radio Shack Pro 96 that is not working. Anyone have any recommendations as to where in Phx I can take it to get repaired? Prefer not to send out to get fixed.
Thanks,
Rchjr
Old 10-07-2018, 5:52 PM
iMONITOR's Avatar
Question
What kind of problems are you having?
Old 10-07-2018, 6:06 PM
Location: Vrigo Super Cluster, Milky Way Galaxy, Sagatarious Arm, SOL system, Earth, California, Bay Area.
rchjr - I do not recommend fixing a Pro 96 as its Hardware Limited to only onboard programming and its likely a repair might cost more than a WS 1080/1088 scanner NEW.
the Pro 96 is also no longer Supported and you cant add a computer. the Pro-688/ WS 1088 is a better scanner, it has a SD card with the Entire USA/Canada database on it. and you can update with a Windows computer. Programing by PC is much easier and faster than by hand, Bonus, you also get FREE Lifetime updates for the Database and more.
I'm not sure where in AZ you can repair a Scanner, perhaps try HRO ? Ham Radio Outlet.
Old 10-07-2018, 6:21 PM
iMONITOR's Avatar
The PRO96 can be programmed using a PC. Win96, ARC96 and PRO96Com software supports the PRO96.
Additional info here:
https://wiki.radioreference.com/inde...rting_Software
Old 10-07-2018, 7:26 PM
rchjr - Sorry, I miss read INFO on Radio Ref - database, yes it supports PC download.
however, Public Safety is Federally Mandated to upgrade to Digital Systems beyond P25.
Phase 2 Trunking and NXDN, iDAS are superior radios and offer Public Safety a lot.
Old 10-07-2018, 7:27 PM
I use pro 96 software to program it. When I turn it on it seems as if the squelch min max knob is not working properly. I have had this for a long time and this is the only time it has acted up. Other times I turn it on and it seems as if it works ok. Kind of a intermittent thing.
Weird.......thanks for the responses.
Rchjr
Old 10-07-2018, 10:01 PM
iMONITOR's Avatar
Rchjr
I'm assuming you're monitoring analog systems, as digital does not use the squelch control?
Did you try a little squirt of electronic contact cleaner in the potentiometer? Do not attempt this if you're not comfortable taking things apart and putting them back together. Or get an experienced friend to help.
Old 10-08-2018, 2:55 PM
I will give it a shot, contact cleaner - where would I get some at? Radio shack?
Thanks,
Rchjr
Old 10-08-2018, 3:46 PM
K7MFC's Avatar
I'm pretty sure all the RadioShack locations in PHX have closed, unfortunately. Fry's has what you need:
https://www.frys.com/product/3051679
Matt Callahan | K7MFC | WRAA720
K7MFC.com | Arizona GMRS Repeater Club
var radioList = new List<Radio>();
Old 10-08-2018, 10:03 PM
Thanks, Ill get down there and buy a can and give it a shot.
Rchjr
Tags
pro 96
