I thought this had been discussed before but maybe not. Anyway, I know from one person who works there that radios were changed out in the trucks quite awhile back. I'm not saying none of the analog sites still exist or that they aren't online but they aren't being used, at least not in this region.
Yes it has been discussed, but as it is an developing system, I want to get the most recent data, and keep it accurate. Until the full system is converted and I can put the analog to bed, I will keep asking.
I know its not as exciting as the AWIN, but we do need to keep the data accurate and up to date. Especially with scanners like the HP series including the X36's, TRX series, the new SDS100 that folks roll plug n play with and use the GPS location based scanning etc... If someone just runs with the DB and is not savvy on what is on and how to verify that info, they will scan both systems, and if the analog is offlined it is just slowing the scanners down being in an active scanning. SO once we fully know that old system is gone, I can send it to the TRS graveyard and it will be out of the way.
I miss being able to gas up the ride, and run all over MS, LA, AR, TN, and parts of AL and just "War Scan" as it were and gather and verify data. But since that cant happen I depend on all you folks out there to be my eyes and ears on the ground so to speak. You guys n gals are how we get the site numbers, accurate CC and ACC, site NACs.... etc
Asking in the multi state forum gets little to no info, as most of our users do not give a flip about it if it ain't talked about locally, so I take the risk of getting hit with flags for asking locally as the mods do not want the forums flooded with the same thing in multiple forums.... I am willing to take that hit because frankly it is 80% more likely to get results in local forums.
