winklehawk702
I am having this strange volume issue on my feed that I can't figure out. Everything will be going just fine for about a few weeks, then the volume “spikes” overpowering everything and nothing can be made out over the feed.
No changes are made to either my scanner or the line in volume levels. The scanner volume is set to "11:00" and my "line in" level is at about 40%.
A reboot of the PC seems to bring everything back to normal.
Feed:
Las Vegas Metro Police - Northwest Area Command Live Scanner Audio Feed
Scanner:
Realistic Patrolman PRO-2025 from a friend
Using ScannerCast v 13
I did upgrade to v14 and the volume spiked almost immediately, so I went back to v13. The feed was good for a few hours, then it happened again so that ruled out the upgrade. May try going to v14 later.
I figure I could reboot the PC once a week.
Any other ideas?
Feed:
Scanner:
Any other ideas?
