hi i have issue connection drops and picks up i run windows 7 64bit and scanner cast here is the error i get in log.
31-Aug-2010 23:51:22 Connection complete to RR server audio1.radioreference.com/122686347
01-Sep-2010 00:00:14 Write to Icecast server failed Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host.
01-Sep-2010 00:00:14 Disconnect details follow (for debugging if necessary):
Message: Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host.
Source: System
TargetSite: Void Write(Byte[], Int32, Int32)
StackTrace: at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size)
at ScannerCast.ScannerCast.PushClientThread()
--Message: An existing connection was forcibly closed by the remote host
Source: System
TargetSite: Int32 Send(Byte[], Int32, Int32, System.Net.Sockets.SocketFlags)
StackTrace: at System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)
Socket error: 10054
01-Sep-2010 00:00:24 Error status from Icecast (105): HTTP/1.0 403 Mountpoint in use
01-Sep-2010 00:00:44 Connection complete to RR server audio1.radioreference.com/122686347
help please this does kick people from my feed. I dont use AVG and have looked everywhere for solution
Source: System
Source: System
Socket error: 10054
