Below is a diagram of my new setup. It seem like every time I fix one issue, another pops up. I currently have 2 scanners on this setup. The problem: Audio from scanner 2 is bleeding onto Scanner 1's feed. Scanner 1's audio line is fed directly into the computers on-board sound card. The audio cable from scanner 2 is fed through a USB external sound card. It is important to note the bleed from scanner 1 is not bleeding into scanner 2's feed.
Also, (I hope I can explain this effectively)... The bleed audio from scanner 2 does not effect the scanning of scanner 1. In other words, While listening to the scanner 1 feed, it will continue to air the public safety traffic just fine and scan despite the bleed, when scanner 2 breaks squelch for a transmission, it airs over both the scanner 1 and 2 feed even though scanner 1 is still scanning.
Both scanners are 2 week old PSR-410's
Any ideas?
Any ideas?
