Alpha Tags
Lexxx
Kitchener, Canada
Hi
It has been suggested I repeat this question in this forum.
I currently stream 4 feeds to RR. I use Simplecast an Icecast server and let RR access my Icecast server at 4 mount points for the feeds.
I'm thinking of trying Scanner Cast and would like to generate Alpha Tags on an embedded player on the web site I run
I already have the RR embedded player on different pages for my 4 different feeds, but need to know if there is some way to embed a Java player, or some kind of player in my web pages to show tags matching the audio.
I've read what I can from the info on this site and the Scanner Cast info does imply I can use alpha tagging for the BCD996T and the two BCT 15s I have. I'm sure the alpha tags will work on the RR site (or Broadcastify site), but I want the tags to work on the pages on my site.
Does RR/Broadcastify have a player (the code for the player) that will display tags that I can embed in my web pages?
Peter
Traj
Woonsocket RI
I too have been looking for a way to embed a player on my site that will display ALPHA TAGS. Apparently this is a closely guarded secret.
04Z1V6
Castle Rock, Co.
No it is not take a look around on the site this is answered all the time. The Winamp, and Java web player, are just a few that do this.
Traj
Woonsocket RI
Thanks. I have looked around. I have yet to find the solution. Perhaps you could provide a link to some code to embed one of the players you speak of onto a web page.
So far the only way I know of is to show the alpha tags on a desktop application such as iTunes or WinAmp.
ProScan
Software Provider
Ontario, Calif.
