scottybo14
I have a buzzing in the background of my feed. I've looked up options on how to fix it but I'm not sure exactly what the difference in my problem and others are. I've seen anywhere from a 3.5mm Mono cable to a more powerful AC adapter or ground loop isolator.
Using a Pro 163 base thru a Line-In port with what is presumably a 3.5 stereo cable. Line in volume is at 4 on PC, using radio for main volume source.
My feed: Mobile County Sheriff, Fire, and EMS
