The RadioReference.com Forums
-   Broadcastify Administration (https://forums.radioreference.com/broadcastify-administration/)
-   -   Background noice. (https://forums.radioreference.com/broadcastify-administration/350987-background-noice.html)
Josue75 03-31-2017 10:18 PM
Background noice.
Hello, I am having a lot of background noice when frequency traffic is empty. Once communication is detected sound is loud and clear. I have adjusted squelch, but no success. I am currently using a 3.5mm aux cable to the raspberry pi 3.
Also when I unplugged the audio jack and listen to frequency, there is no background noice when empty. Seems to only happened when audio cable is being used.
Scanner uniden bc75xlt
Raspberry PI 3
USB audio dongle (tried 2 type of USB dongle)
3.5mm cables. (Tried 2 different cables?
L
alabamarailfan 04-01-2017 1:25 AM
Something like this has helped cut the noise out of the feeds I have set up!
https://www.amazon.com/Mpow-Ground-I.../dp/B019393MV2
Josue75 04-01-2017 1:30 AM
Will give it a try. Thank you
