I use multiple sessions of WinAMP at home.
Just go into the WinAMP options and select 'Allow Multiple Sessions'.
Also, select 'Repeat' and it will try to reconnect if you loose the feed for a while.
That's been 'Bullet Proof' for me.
Scanner Radio Pro, Scanner Radio, XiiaLive, and others on my Androids.
Both versions of Scanner Radio will run separately.
Rich
Edit: One example. On this computer I'm listening to seven of my private feeds, one of my Broadcastify feeds, and logging two of my scanners.
Also running the FreeSCAN server so I can control that scanner from my Android using the RemoteFS app.
