audio3 ded :)
blantonl
Founder and CEO
Staff member
Super Moderator
San Antonio, Whitefish, New Orleans
audio3 died - we failed it over to a new box.
If you are using a barix streaming device the new ip address is 174.37.110.68
Otherwise, stop and start your feed and all should be well if you are on audio3
station09
Still can not get server site to work. I did the command prompt and type ipconfig/flushdns. After I did that it did connect to Icecast2 server. But after that it would not allow me to connect to the server, on the server end it shows the following 404 not available. Now it will not connect the Icecast2 server. Anything I can try. I made no changes on my end. Was working great a few hours ago. It all happen after your system went down. Thank you for any help
