Talk Group Monitor
# Scanner connection parameters
# SCANNER_HOST should be set to the IP address or hostname of the machine
# your scanner is connected to and which is running serproxy.
# SCANNER_PORT should be set to a port number defined in the serproxy
# configuration file (serproxy.cfg). By default,
# 5331 = COM1, 5332 = COM2, 5333 = COM3, and 5334 = COM4. If
# you need to use a higher COM port number you'll need to
# add it to the serproxy.cfg configuration file.
SCANNER_HOST=192.168.1.101
SCANNER_PORT=5331
# Icecast configuration
# Comment out the lines below if you are not using an Icecast
# server to have the alpha tags sent to SimpleCast.
# ICECAST_HOST should be set to the IP address or hostname of your
# Icecast server.
# ICECAST_PORT should be set to the port number your Icecast server
# is running on.
# ICECAST_URI Change "/live" to be the mount point your stream is using.
# ICECAST_USERNAME should be set to the same value as <admin-user> in the
# <authentication> section of your Icecast configuration
# file.
# ICECAST_PASSWORD should be set to the same value as <admin-password> in the
# file.
# ICECAST_RESPONSE should not be changed.
ICECAST_HOST=audio1.radioreference.com AGAIN, MY SEVER IP OR RR IP ?
ICECAST_PORT=80
ICECAST_URI=/admin/metadata.xsl?mount=WHAT GOES HERE ?&mode=updinfo&song=%s
ICECAST_USERNAME=admin
ICECAST_PASSWORD=WHAT GOES HERE ?
ICECAST_RESPONSE=HTTP/1.0 200 OK
# SimpleCast configuration
# Uncomment the lines below to have alpha tags sent to SimpleCast
# instead of to an Icecast server.
# SIMPLECAST_HOST should be set to the IP address or hostname of the
# machine that is running SimpleCast.
# SIMPLECAST_PORT should be set to the port number SimpleCast has
# been configured to listen for meta-data on.
# SIMPLECAST_URI should not be changed.
# SIMPLECAST_RESPONSE should not be changed.
#SIMPLECAST_HOST=192.168.0.11
#SIMPLECAST_PORT=8181
#SIMPLECAST_URI=/update.html?title=%s&duration=0
#SIMPLECAST_RESPONSE=HTTP/1.1 200 OK
# Miscellaneous
# SEND_IDLE_AFTER After the specified number of seconds has passed with no
# audio, the title following "Scanning," in titles.txt is
# sent. Specify 0 to turn this off.
# SEND_UNKNOWN Set this to 1 if you would like for Talkgroup Monitor to
# send titles to Icecast/SimpleCast for frequencies and
# talkgroups not found in titles.txt, this is useful when
# the scanner is in search mode. Talkgroup Monitor will
# send "Talkgroup nnnn" or "nnn.nnnn MHz".
# SEND_AFTER_NO_TITLE_CHANGE
# After the specified number of seconds has passed with no
# title change, the title following "Scanning," in titles.txt
# is sent. Specify 0 to turn this off. Use this parameter
# if SEND_IDLE_AFTER seems to have no effect.
# SEND_DELAY Set this value to 1 if you need for Talkgroup Monitor to
# wait a certain amount of time before sending some titles to
# Icecast/SimpleCast. This is useful if your scanner stops
# on a particular frequency/talkgroup for a short time and
# then resumes scanning if the CTCSS code doesn't match or
# the talkgroup is encrypted. If you set this to 1 you
# *must* specify/add a delay value (in milliseconds) for each
# title defined in the titles.txt file.
# OLD_TITLE_MATCHING
# In versions before 3.3.1, due to the way the
# frequencies/talkgroups received from the scanner were
# compared to the values specified in the titles.txt file, if
# talkgroup 48 was received from the scanner, a line in
# titles.txt beginning with 48 (such as 48123) would be
# considered a match as well as a line specifying exactly 48.
# In versions 3.3.1 and later, frequencies/talkgroups
# received must match the frequency/talkgroup specified in the
# titles.txt file exactly. Set this parameter to 1 if you need
# for Talkgroup Monitor to perform title lookups like it did
# in earlier versions.
SEND_IDLE_AFTER=30
SEND_UNKNOWN=0
SEND_AFTER_NO_TITLE_CHANGE=0
SEND_DELAY=0
OLD_TITLE_MATCHING=0
