Shawnee County, KS
kswx29
The Fire/EMS feed for Shawnee County has been playing a TV show or something, and the Law Enforcement channel is down, I was wondering if anyone knew why?
Rob_K
Tolland County, CT
I think the best way to address this is to use the "REPORT A PROBLEM" button on the feed page. This should go directly to the person providing the feed.
cinsu
WT44
This is due to an issue with the radioreference streaming upload program. The computer I use for the stream is not used for any other purpose except streaming. I run the radioreference stream on it and then I have a private stream set up into a television studio for another purpose. This computer is setup to reboot weekly. When it reboots the radioreference program is defaulting to the wrong audio card and capturing the television audio. I have to manually go in and switch it. I am in a place where I don't need the other feed so I disabled that audio card however now the stream will not show up on radioreference. I am streaming and show everything online but it still shows offline.
