Feed No Longer Associated With Account
ecanderson
Colorado
Came home from dinner this evening to see that ScannerCast was down.
My feed has become disassociated from the account. There was supposedly no audio (as noted in a Problem from 8-30-13), but I received no notification of this by email. Now when firing up ScannerCast, I receive the message
Radio Reference Feed Auto-Config Error:
There are no feeds associated with the username 'ecanderson'
Check User Name and Password, or contact Radio Reference for assistance.
which is odd, since I can still manage the account from the web page.
Mount point is /567277048
Unable to restart the service in order to verify if there is indeed an audio issue. Sounds fine on my end.
ecanderson
Colorado
No luck here. I will reinstall ScannerCast to see if there's something amiss. See below for what it reports:
ecanderson
Colorado
Delete and reinstall of ScannerCast didn't change anything. Application still claims there is no feed associated with my login name.
richtidd
San Mateo, Ca
Your feed appears to be disabled by Gordon on 2013-09-06 at 21:16:20.
Suggest you check your email as there most likely was a problem with your feed.
ecanderson
Colorado
There may have been a problem with the feed, but I received no email.
Now that I am prepared to determine the nature of any problem, I am unable to test for success since I cannot connect back to Broadcastify with ScannerCast.
I attempted to 'un-disable' the feed, but have had no success that would permit me to retest and get things online again.
Firemann59
I am also having that same problem. The email I received showed the feed went down on Saturday. I was out of town and just found out about the problem this morning.
richtidd
San Mateo, Ca
Your feed was disabled by Gordon on 2013-09-07 at 19:36:44.
Here is the status message he put up:
Status: Feed disabled by Broadcastify.com due to the fact that there has been no audio for two weeks and problem reports have gone unanswered.
Suggest you check your email.
Firemann59
I received no notice of the feed being down until Saturday morning. It was up and running on Friday. How do I get my feed reset so I can continue broadcasting? My account shows no problems with my feed.
