I have a feed I have been running for years without issue, but since late last week it has been going offline multiple times per day.
It is on a dedicated Debian Whezzy box running Darkice. I was on 1.1, but after having issues I upgraded to 1.2 - but the issue persists. I have been running in the foreground with -v 10, but I am still receiving no specific errors on the console when it goes offline.
Anyone else been having similar errors? I am posting the .cfg and output below if anyone has any suggestions.
Thanks!
Thanks!
Code:
# sample DarkIce configuration file, edit for your needs before using
# see the darkice.cfg man page for details
# this section describes general aspects of the live streaming session
[general]
duration = 0 # duration of encoding, in seconds. 0 means forever
bufferSecs = 5 # size of internal slip buffer, in seconds
reconnect = yes # reconnect to the server(s) if disconnected
# this section describes the audio input that will be streamed
[input]
device = default # OSS DSP soundcard device for the audio
sampleRate = 22050 # sample rate in Hz. try 11025, 22050 or 44100
bitsPerSample = 16 # bits per sample. try 16
channel = 1 # channels. 1 = mono, 2 = stereo
# this section describes a streaming connection to an IceCast2 server
# there may be up to 8 of these sections, named [icecast2-0] ... [icecast2-7]
# these can be mixed with [icecast-x] and [shoutcast-x] sections
[icecast2-0]
bitrateMode = cbr # average bit rate
format = mp3 # format of the stream: ogg vorbis
bitrate = 16 # bitrate of the stream sent to the server
server = audio1.radioreference.com
# host name of the server
port = 80 # port of the IceCast2 server, usually 8000
password = xxxx # source password to the IceCast2 server
mountPoint = xxxx # mount point of this stream on the IceCast2 server
name = xxxx
# name of the stream
description = xxxx
# description of the stream
url = http://www.yourserver.com
# URL related to the stream
genre = my own # genre of the stream
public = yes # advertise this stream?
localDumpFile = dump.ogg # local dump file
password = xxx # source password to the IceCast2 server
mountPoint = xxx # mount point of this stream on the IceCast2 server
name = xxx
description = xxx
DarkIce 1.2 live audio streamer, darkice - DarkIce is a live audio streamer. - Google Project Hosting
Copyright (c) 2000-2007, Tyrell Hungary, Tyrell Hungary Corporation
Copyright (c) 2008-2013, Akos Maroy and Rafael Diniz
This is free software, and you are welcome to redistribute it
under the terms of The GNU General Public License version 3 or
any later version.
Using config file: /etc/darkice.cfg
27-Jul-2015 08:30:13 Using ALSA DSP input device: default
27-Jul-2015 08:30:13 buffer size: 220500
27-Jul-2015 08:30:13 encoding
27-Jul-2015 08:30:13 scheduler high priority 99
27-Jul-2015 08:30:13 Using POSIX real-time scheduling, priority 4
27-Jul-2015 08:30:13 HTTP/1.0 200
27-Jul-2015 08:30:13 set lame mode 3
27-Jul-2015 08:30:13 set lame channels 1
27-Jul-2015 08:30:13 set lame in sample rate 22050
27-Jul-2015 08:30:13 set lame out sample rate 22050
27-Jul-2015 08:30:13 set lame bit rate 16
27-Jul-2015 08:30:13 set lame quality 9
27-Jul-2015 08:30:13 set lame lowpass frequency 0
27-Jul-2015 08:30:13 set lame highpass frequency 0
27-Jul-2015 08:30:13 set lame psycho acoustic model 1
27-Jul-2015 08:30:13 set lame error protection 1
LAME 3.99.5 32bits (LAME MP3 Encoder)
CPU features: MMX (ASM used), SSE (ASM used), SSE2
Using polyphase lowpass filter, transition band: 5424 Hz - 5690 Hz
27-Jul-2015 08:30:13 MultiThreadedConnector :: tranfer, bytes 0
27-Jul-2015 08:30:13 MultiThreadedConnector :: ThreadData :: threadFunction, was (thread, priority, type): 0x9a4e9a0 4 SCHED_FIFO
27-Jul-2015 08:30:13 MultiThreadedConnector :: ThreadData :: threadFunction, now is (thread, priority, type): 0x9a4e9a0 1 SCHED_FIFO
