Go Back   The RadioReference.com Forums > Site Administration Forums > Broadcastify/Live Audio Administration
Broadcastify/Live Audio Administration - Administration topics for live audio broadcasting on Broadcastify.com. This forum is for feed providers to get support. Other audio questions go here: Streaming /Broadcasting / Audio Recording forum
Old 12-08-2016, 9:40 AM
blantonl's Avatar
Founder and CEO
Default audio3 outage - 12/8/2016
Good morning folks.
Audio3 has been experiencing a DOS (denial of service) attack - to mitigate the issue we've failed over to a hot standby and implemented firewalling procedures to mitigate the problem.
The failover will take a couple hours to completely propagate the new DNS information across the Internet. However we're already seeing feeds coming back online on the new server so it will be a gradual process.
Thanks,
Lindsay C. Blanton III
CEO - RadioReference.com / Broadcastify
Facebook: RadioReference | Broadcastify | Twitter: @RadioReference
Old 12-08-2016, 11:52 AM
SenorMoofer's Avatar
Originally Posted by blantonl View Post
Good morning folks.
Thanks,
Thanks for the quick action. Keep up the good work!
Old 12-08-2016, 2:33 PM
Mylan's Avatar
I have to manually reconnect my feed when it goes down.... I just tried and it is still not connecting. ..Can someone possibly post to this thread when the audio3 is back in business or we are otherwise good to go. Thanks in advance!
Old 12-08-2016, 3:28 PM
n0nhp's Avatar
Audio 3 has been working for me for 4 or more hours, I did find that I had to change the DNS server on my feed machine to get the new IP address.
Changing to the Google server 8.8.4.4 resolved the problem immediately. My router (which the server was pointing to) using my ISP's DNS server would not resolve to the new address. Rather than bomb my working feed with re-assigning the DNS server in the router, I just pointed the computer at the new server and connected on the first try.
Bruce
N0NHP
Old 12-08-2016, 3:52 PM
Still no joy out here in the SF Bay Area
Old 12-08-2016, 5:00 PM
Still down this morning here in Australia. :-(
Old 12-08-2016, 6:55 PM
No dice here either. Flushed dns and did serveral nslookups against different dns servers and all resolved same ip.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Old 12-08-2016, 7:17 PM
Scan-Denver's Avatar
So my feed (Denver Police, Fire, & EMS) is also on the audio 3 server. I had to re-populate the server information in RadioFeed client (RadioFeed does this automatically by entering in your login info) and it started working again (6:17PM Denver Time).
Bill
Email
Scanning/Streaming Denver Police, Fire, & EMS Online
GRE PSR 500 (2), RTL-SDR, AirSpy
Old 12-08-2016, 7:20 PM
I can't even ping audio3, let alone log in to it.
Old 12-08-2016, 7:23 PM
Try pinging audio3.broadcastify.com. my feed was pointed to radioreference. I did a auto configuration again, it went to broadcastify and then connected ok.
Old 12-08-2016, 7:26 PM
Champion. That was exactly the problem. Changed servers and it's happy again.
Old 12-08-2016, 8:49 PM
For someone that is showing that the server is up and responding, can you ping the address you're using and let me know? I'm getting 174.37.110.68 and I can't ping the server. I cannot connect to the service port either but I can connect without a problem to audio1:
root@radio:/home/x# nc -v -w 10 audio3.radioreference.com 80
nc: connect to audio3.radioreference.com port 80 (tcp) timed out: Operation now in progress
root@radio:/home/x# nc -v -w 10 audio1.radioreference.com 80
Connection to audio1.radioreference.com 80 port [tcp/http] succeeded!
Thanks for any help!
Old 12-08-2016, 8:50 PM
You need to point to audio3.broadcastify.com
Old 12-08-2016, 8:54 PM
Not the reply I was expecting but I definitely appreciate it. I hadn't noticed that my technicals had changed to broadcastify.com. My feeds back up now. Thanks!
Old 12-08-2016, 8:58 PM
Excellent. Sorry I could not ping from phone to tell you. I guess they didn't update dns for old rr domain name.
Old 12-08-2016, 9:13 PM
Mylan's Avatar
Thank you Rob_K..... I would have never figured that out on my own...
Old 12-09-2016, 8:26 AM
Thanks Scan-Denver
I would not have been able to fix mine without his post!
Old 12-09-2016, 10:05 AM
It seems as if they changed the domain (radioreference --> broadcastify) at some point. This caused me an extra 3-4 hours of downtime
Old 12-09-2016, 10:26 AM
My feeds are run off an HP thin client and I have the write filter enabled. Anytime I reboot, it reverts back to original config. I only reboot it once a year and I haven't updated the config in at least 3 years. Next time I reboot, it's going to revert back to RR domain name and I'll need to remember why it won't connect!
Old 12-09-2016, 2:05 PM
thinder's Avatar
Default Audio 3
Thanks for heads up, Kitsap WA back up
