So My county is going to switch from a conventional analog system to a P25 Phase 2 system. Sometime in next year or two. The contract for the upgrade contract will be approved at the end of the month most likely. They maybe a switch in frequency as well. But latest information is that may happen later. I know the county has End of Life on the dispatch systems in 2018. So Image the new plan will have to new system live by then.
The question is about my feed. Do I need to apply for a new feed to stream the new system? Or that only necessary if they switch frequency? Or am I good the way I am and simply update the feed info.
I am not planning on adding another other then if additional ops fire and ems channels are added.
