Sorry if I a resurrecting an old topic.
I have recently begun using an iPad to listen to RR Audio feeds. I have tried several apps, particularly "Scanner 911 HD", "S.R. Deluxe", and "Scanner +".
I have noticed on all of these apps that the meta tag data and the corresponding audio are noticeably out of sync. The audio tends to lag the meta tag by several seconds. So the tag pops up, nothing is hear, the tag goes away, then the audio start. It makes the tag data pretty much useless. It seems to always, consistently be like this. Meanwhile, if at the same time I monitor the same feed on a PC, the tag and audio are in sync. So it seems the feed itself is ok, but it must be something common and specific to the iPad apps.
Wonder if anyone has ideas or suggestions on how to deal with this.
TIA
TIA
