Go Back   The RadioReference.com Forums > Site Administration Forums > Broadcastify / Live Audio Listener Support
Broadcastify / Live Audio Listener Support - This forum will act as a place for individuals who listen to feeds to provide comments or concerns about specific feeds. All feed providers should monitor this forum for feedback on their feeds.
Old 05-03-2017, 4:33 PM
Default My feed possibly looping
I have heard the same drill of a location 4 times in the last 2 days with the same units. Is my feed looping?
Old 05-03-2017, 4:35 PM
mule1075's Avatar
What player are you using?
Sent from my SM-S907VL using Tapatalk
Uniden BCD536HP/436HP/796D/250D Motorola HT1000/GM360
Old 06-08-2017, 9:38 AM
richtidd's Avatar
Live Audio Administrator
You maybe listening to the feed via the web or Java player.
If so, the looping or repeating, echo, re buffering or stopping, of the feed is a known bug with the web player & sometimes with WMP and the Java player as well.
What you are hearing is audio that was cached by the browser the last time you listened along with the current feed audio.
To avoid this problem, I listen to feeds with WinAmp or iTunes.
However, you can try clearing your browser cash.
To clear the Java Plug-in cache:
1.Click Start > Control Panel.
2.Double-click the Java icon in the control panel.
The Java Control Panel appears.
3.Click Settings under Temporary Internet Files.
The Temporary Files Settings dialog box appears.
4.Click Delete Files.
The Delete Temporary Files dialog box appears.
There are three options on this window to clear the cache.
1.Delete Files
2.View Applications
3.View Applets
5.Click OK on Delete Temporary Files window.
Note: This deletes all the Downloaded Applications and Applets from the cache.
6.Click OK on Temporary Files Settings window.
Note: If you want to delete a specific application and applet from the cache, click on View Application and View Applet options respectively.
Richard Tidd
Broadcastify.com
richtidd@broadcastify.com
My online scanners:
SMCo, Tuolumne Co
Old 06-09-2017, 9:12 AM
My feed sometimes loops when I am messing with it. I typically shut off my feed, restart the computer, and it usually works fine after that.
Encryption Kills Interoperability
Radio Shack Pro-94 / Pro-197 / Pro-651, Uniden BCD996XT, ICOM A-214, Baofeng UV-5R V2+ (3) / UV-82, Kenwood TK-880, Motorola HT-750 / CT250, TYT TH-7800
