Go Back   The RadioReference.com Forums > Site Administration Forums > Broadcastify / Live Audio Listener Support
Broadcastify / Live Audio Listener Support - This forum will act as a place for individuals who listen to feeds to provide comments or concerns about specific feeds. All feed providers should monitor this forum for feedback on their feeds.
Old 02-17-2018, 6:56 PM
JDrisc3480's Avatar
Default Question about background noise
For the past few days now, every time I listen to Broadcastify there is constant hum in the background. It is just loud enough to where some of the transmissions are not too clear. Just curious as to what might be causing this?
thank you,
Jim
Old 02-17-2018, 7:45 PM
kgowen44's Avatar
thank you,
Jim
Does this happen on all feeds?
Old 02-17-2018, 11:02 PM
Not on my feeds
https://www.broadcastify.com/listen/feed/23831
https://www.broadcastify.com/listen/feed/25781
Background hum is a common problem with many feeds due to the connection requirements of Broadcastify. My feeds drive inaudible audio to BCastify to keep the feeds alive during dead air times. A lot of feeds use a background audible noise to stay alive. It's a problem that should be addressed by Broadcastify as they are wasting bandwidth with this requirement.
Old 02-18-2018, 3:13 AM
JDrisc3480's Avatar
No, I only hear is on certain feeds.
Old 02-18-2018, 3:32 AM
kgowen44's Avatar
Yeah that might be normal there is some interference on my feed but I believe that is because of the cheap USB soundcards I have.
Old 02-18-2018, 10:31 AM
For the person running the feed, if there is a constant hum behind all audio they need to add a ground loop isolator. It can bring down a lot of the hum and is pretty cheap. I have it on mine and it has no background hum after adding it.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Old 02-18-2018, 3:51 PM
cmdrwill's Avatar
Nick nailed it, ground loop problem(s).
