I'll start off by saying I'm a fire buff who knows nothing about scanners. I use Broadcastify and the 5-0 Radio app (which I believe just picks up Broadcastify feeds)
I live in Marin County, Ca, and listen to the Marin County Fire Agencies stream. In the past, the stream contained the primary dispatch channel, as well as all the control channels for the county fire departments. Essentially, you could hear the dispatch for all the departments in the county, as well as the communication between dispatchers to units, units to units, and command channels. Now, the feed only seems to contain the primary dispatch, no further communication.
Any idea why this happened, or how I can listen to all the control channels? Obviously hearing just the dispatch is not very exciting... I do not own a scanner, but am not opposed to getting one, however mobile device streaming would be ideal.
Thank you in advance!
