mipsyop
Anyone know if these are legal in the states? I have come across conflicting info from other sites. Some say the 777 is the only one licensed for use here while others say both are. Any info would be great! Thanks
No more dangerous then all the legal radios that have been "opened up" by licensed operators. JUST KEEP IT OUT OF THE WRONG HANDS
The question was are they legal, and the answer is no. Niether is any radio that has been "opened up" and once was legal. The second you mod it to transmit outside its indended range than it voids the FCC cert.
Oh so absolutely not true, you can legally modify any amateur transceiver to cover outside the amateur bands and its perfectly legal. This goes for HF, VHF or any band for that matter, modify away and parade the radio through the FCC offices and all they can say is nice modded radio you got there. This same question was asked of Riley Hollingsworth of the FCC and he backed it up.
Now transmitting outside the band you are licensed for or using a non type accepted radio on commercial frequencies is another problem and obviously not legal. Amateur operators can build or use practically anything to transmit as long as it meets current harmonic suppression specs. It may be illegal to import a Puxing style radio that is not FCC type accepted but once its in the US it can be legally operated by a licensed radio amateur within the amateur bands. If someone imports a number of these non type accepted radios with intent to sell that is a separate legal problem where the FCC and US customs can intervene.
There is an entire community within the amateur radio hobby that collects and operates surplus military radios from every corner of the globe. Many of these radios were never type accepted for anything other than military use which does not answer to FCC rules yet they are perfectly legal to use on amateur radio if they meet current harmonic specs.
prcguy
Hi guys...a new member here from Iran.
Just bought a pair of puxing px 888 and cant get it to work on long range...any tips to help me out on this as im quite an amateur!
Would appreciate it, thanks.
To mrthick:
For US readers and everyone else:
Having said that, I own a Puxing radio and while it performs well, I wish I had just bought a VX-150 for ~$20 more. It will scan channels faster and have more features like tone detection, etc. Also, I have read about amateur repeater owners not allowing these radios to be used on them since they don't comply with FCC regulations. If your new to the hobby, AVOID these radios! It's not a good way to get started!
Hi, thanks for your reply, mine is the UHF version. I found it very weak and returned it to the store and am replacing it with a motorola GP 380 VHF.
Any experience with this version on the range of this in a city and is this any good?
You can even build your own ham radio equipment for use on ANY part of the spectrum allocated for any ham radio use (which means no playing music or operating like a broadcast station).
don't take this as a negative or heated response to your statement;
