PX888K Help!
KD8TDB
Swartz Creek, MI
Hi I am brand new to the Ham world. I recently bought a px888k it worked fine for a few days. I plugged the radio into the computer to program it and now its locked up and won't do anything. The left side of the screen says "cal" no where in the book does it say anything about "cal". If anyone has any information on how to unlock this, or is there a factory reset? The book that came with the radio does not have very much information.
KD8DVR
Columbus, Ohio
Turn radio off, hold the MENU key while turning the radio on, then press enter when it says RESET?
Hopefully that will bring it back
KD8TDB
Swartz Creek, MI
No luck, still stuck no matter what I do. I e-mailed Puxing and their response was hit the escape button. None of the buttons do anything,hitting escape certainly does not do anything.
KD8TDB
Swartz Creek, MI
here a screen shot of where the radio is stuck.
KD8DVR
Columbus, Ohio
Sorry that didn't work. I don't know what to tell you at this point.
n1nte
Holland, MA
Did you ever find out how to get the radio out of this mode? It appears to be calibration mode (CAL in the display).
KD8DVR
Columbus, Ohio
Perhaps with software and a cable could reprogram a clean file, but read it first, to see if some odd setting has been made.
box23
State of Superior
I have found you get into that mode by pushing the bottom right '#' button. To get back to normal you just push the ESC/M button to cycle through VFO and Memory Mode as usual.
Not really sure what that mode is for. Like was said there isn't any information in the manual. At times I accidentally hit the button and it goes into that mode, usually at inopportune times. Never had a problem getting out of it.
Looking at your picture it appears to be in dual watch mode. I'm not sure if you can have just one "band" in cal and the other not, as with other modes, but try pushing Enter to switch to the B "band". If that works try pushing the ESC/M button.
The only other explanation I can think of is that by connecting it to the computer it messed something up.
mursradio
Solution
You need to change the Work Mode-A and Work Mode-B settings in the Optional Features menu from VFO to Ch. Name. [See image] This will set the radio to power up in the correct mode to display the channel alias names.
Pressing the # key sets the radio to the call channel. You can change this by going to the VFO/Call menu. You will notice that the two frequencies you had on your display before are shown as VFO A and B.
Please feel free to contact me if you have any additional questions.
- Rob
F8DDE
LORRIS, FRANCE
Hello all,
I receive my PK888K 1 month ago, and all is OK before I plugged the radio into my computer. Since I do its locked too. Not any push-button are active. I can push MENU btton, but I cannot enter into menu systeme.
I tried the solutions given above, but none Resolves the problem.
Kind Regards
JC
mursradio
Hello all,
Kind Regards
JC
If you download v1.01 of the software there is a setting that isn't in v1.03 called Manual. It is located in the Optional Features menu. When checked off it is supposed to disallow keypad programming to comply with FCC Part 90 rules here in the US. If you check Manual on then it will allow keypad programming. Again, this setting is for some reason only in v1.01 and not in v1.03.
To obtain this software if you can't find it anywhere else online you can go to the files section of the PX-888K Yahoo Group: Puxing PX-888K Yahoo Group
- Rob
KD8DVR
Columbus, Ohio
I have a suspicion that that option is no longer supported in later models. My radios do not lock out the keypad programming, when used with the 1.01 software. Perhaps, the function is still supported; but in a yet-to-be-released software version.
- Rob
ralden155
HEEEEEELLLLP
Hey I really need help im like a noob in this type of field Programing/installing I recently received a puxing px-888k just to be straight to the point I need help with everything. I have and know all the frequencies I need I just cant seem to download the software and program it manually or through the computer please here is my phone number serious callers only I need to have this radio up and running 347-585-9875
fouyer
same probleme with my puxing !!! help
Dear Om
i have read your problem about puxing 888 k
because today i have the same probleme with this transceiver !
my puxing also in look with call !! before i had plug this to my pc ...
Do you have an solution for this ,
Thanks a lot
best 73
Roger
From France
Havocide
Puxing PX-888k Direct Software Links
Here are direct links to programming software that I use on all three of my px-888k's with a working prolific driver for the data cord. You must use COM4 in "Communication Port". This has been the only combination I have been able to find that will work. The problem with the china data cords are that they are are counterfeit and don't work with most the drivers on the web. Hope this helps!
https://docs.google.com/file/d/0B6wkX8gXl5y_cEFYc3lTYUVKN3c/edit?usp=sharing
https://docs.google.com/file/d/0B6wkX8gXl5y_aHZlelFaa2JfQjg/edit?usp=sharing
