Do I Need a License for my BaoFeng UV-5R?
coollearner
Hi, I'm new here. I'm a beginner of Ham Radios. Actually I don't know much about it now , but I'm very interested and want to learn more about it. I've just bought BaoFeng UV-5R from radioddity.com. I'm aware that some radios require a license to use with. I wonder if this model needs a license, too. I haven't started to use it yet.
QDP2012
Welcome to RR,
Without a license, it is legal to use for receive-only. A license is needed for transmitting. Be careful. Reportedly, that radio is able to also transmit out-of-amateur-bands, for which you will not be licensed, and for which there are penalties.
You can find additional information in these forums by using the search tools and looking for the manufacturer's name or the model number as your search word/words. I learned a lot about this radio by doing this. Some of the technical comments are very informative. General opinions are useful too.
Edit: In case you haven't figured this out yet, license-requirements are based upon the band or frequency you wish to use, not the specific radio model. An amateur radio license is required for transmitting in the amateur bands regardless of equipment used to do so. Similar license requirements exist for business bands, emergency services, GMRS, etc.
Hope this helps,
AK9R
Super Moderator
Central Indiana
To broaden the scope of the answer, a license is required for transmitting in any two-way voice communications service in the U.S. except CB, MURS, and FRS. Have I missed any?
LtDoc
Oklahoma
Cell phones. You missed cell phones. But then, they aren't really radios, are they?
- 'Doc
WB4CS
Northern Alabama
Welcome to the forum! As others have said, in order to transmit on the ham radio bands you will need to get an FCC Amateur Radio License. Getting the entry level Technician license is fairly easy. Check out this website for some information on what ham radio is and how to get licensed: What is Ham Radio
Remember, as tempting as it is, don't transmit on the amateur radio bands without first getting your license. Good luck!
rapidcharger
The land of broken calculators.
Seeing as how the OP asked about a uv5r, it's safe to assume they aren't asking about CB and murs and frs require radios that are certified and meet other specifications to be legal, as I'm sure you know.
N0IU
Wentzville, Missouri
Well sort of technically you don't need a separate license to operate an aircraft radio since radio operator's privileges are included in a pilot's license.
nd5y
Wichita Falls, TX
That isn't true. It has nothing to do with the FAA. Read the FCC Report and Order on elimination of license requirements for ship and aircraft stations.
http://transition.fcc.gov/Bureaus/Wireless/Orders/1996/fcc96421.txt
Also if you take your boat or aircraft out of the country you still need an operator license.
UPMan
In Memoriam
Arlington, TX
Technically, you need a license for all those services. However, CB, MURS, FRS are all "license by rule." Meaning, you are granted a license as long as you follow the rules. You don't have to submit an application or use a call sign for those services.
To the OP's question, it was answered very well in the first reply post.
rapidcharger
Oh come on... you didn't think that the question could be answered without side arguments and going off topic, now did you? :D
You also don't need a license to broadcast on a marine band if you are in your boat on the water.
You'll also need a radio certified for part 80
Bazel
Novato, California
The topic here is radio and license and whether a reply is off topic seems to be a very narrow interpretation to some people.
Technically, the radio is section 90 certified, without looking the whole thing up, it may be he can't push the transmitter button at all even with a GMRS license or a marine license. I'm not sure here, but I suspect the fact it does have a transmit button would make it an illegal scanner.
Just the same I find the other posts interesting and educational and they help me to learn what is right and wrong with these radios.
nd5y
Wichita Falls, TX
As far as I know none of the Wouxun, Baofeng, etc. cheap Chinese radios are Part 95 certified so that means there are no frequencies you can legally use them on in the US without some type of FCC license.
whirley1
wichita, ks
I just talked to the fcc about radios from England and they told me that ALL radios manufactured for use over seas are not fcc legal. These radios operate on slightly different bandwidths then american radios do, so all in all, if the radio comes from england, europe, asia china these are not legal for use in the states.lso that's what the fcc told me less then two weeks ago. so good luck
AC2OY
Belleville,New Jersey
Welcome to the addiction Cool!!! I tuned around my Kenwood for a week listening only before my license and call sign was in the FCC database. If I can help in any way please ask or PM me. Good start maybe find a local ham radio club in your area,they will help a lot!!
