No Audio
AgentCOPP1
Your question is a little vague. When you ping the repeater, is your radio lighting up indicating that it's receiving the courtesy tone but there's no audio? Does your radio just not receive anything?
AgentCOPP1
Okay, so when you transmit with your Baofeng, other people only hear static? Are you able to hear other people?
xxdanielt3
PA
As tedious as it may sound, reset the radio and try it from there. Most Baofeng issues are solved with resetting the radio from my own experiences.
AgentCOPP1
You can save all of your settings first though. Once you factory reset your radio, you can put all of your memories back onto it if you want.
majoco
Stirrer
New Zealand
but the person on the other side hears notjing but noise
So your transmission has no modulation - is that what you are saying? Are you sure you're pinging the repeater if you hear nothing? Can you listen to the repeater output frequency on another receiver?
