New Puxing PX-888K or fake
dooby91
Plymouth, IN
Just recieved my px-888k off of ebay yesterday. First thing I noticed is the cover for the led fell off after five mins. Ok then im looking and the buttons and the enter button says v/m and the esc/m says a/b. The I read the manual and it's totally wrong. Not just translated wrong but it seems like its for another radio completely. Really confusing. Then I get the software from Puxing's website and it doesn't work. Did all kinds of fiddling with the serial/usb cables and drivers etc... then I start to think that I don't have the right software. Tried version one and three. Pretty sure the cable is good because its working with some kenwood radios I have on the same computer. There are all kinds of weird differences I'm seeing also. Screen is selectable from orange/yellow/green instead of blue/purple/orange. The icons and display are different as well. This is so weird. I hope I didn't get a chinese knock off of a chinese knock off radio. But that is just my luck. Nothing on any of the forums on how to program makes sense or works well either. Been figuring it out as i go. got some repeaters punched in but would like to be able to use the software too. I can add pics tommorow if it helps.
davewhall29
Knoxville, TN area
I have a 888K and mine says PX888K just above the screen on the right. And the buttons across the top row are "MENU" "ENTER" "ESC/M" from left to right. Without looking at the radio, I couldn't be sure. I wonder if you have the newer version the Px-UV973? I just purchased the newer 973. It has no writing above the screen (like the 888) and there are four buttons under the screen "MENU" "ENTER" "VFO/MR" "A/B".
Pull the battery off and there will be a label on the radio that tells you the model number.
If you could post a photo then I might be able to help you, as I am fairly familiar with the Puxing radios. At least I can try anyway.
felixthecatz
Hi Dooby91
I have the same problem with my px-888k , whats the program you used for configuring the radio because the puxing px-888k i doesn't work
thank
mikajlo
Same here :(
Even LED cover fell off after few minutes :)
Hope its a new model and not a fake.
KD8DVR
Columbus, Ohio
I saw the photo, as it was uploaded to the 888k Yahoo group. Just seeing new posts, I revisited this issue. It is not an 888k or a 973. As a matter of fact, the button labeling looks nothing like any Puxing radio. I remain at a loss.
presw
Patchogue, NY
I have the same knockoff of a knockoff PX-888K
I have been playing with this a few hours today and am uncovering a feature I don't understand. When you program PF1 to "DIAL" and tap the side button the radio emits a data burst like MDC-1200 but doesn't sound familiar. Has anyone got an idea?
Here are my discoveries so far:
button differences:
per manual: MENU ENTER ESC/V
actual:.........MENU ...V/M.... A/B
[LOCK/UNLOCK]
menu...*
[MENU]
menu... rotate to select
menu... rotate to change
v/m to save
v/m to exit
[CTCSS/DPL]
menu...C-CDC for both, or T-CDC for TX & R-CDC for RX
menu
press * to toggle tone or digital
rotate to tone or code
v/m to save
v/m to exit
[MEMORIES]
start with a VFO with ALL parameters;
menu
v/m (notice flashing memory number, change)
menu=store
[MISC]
in menu, PF1 can be set to OFF, ALERT or DIAL
........................OFF .........ALERT............DIAL
short press:.........-............TX alarm.........MDC???
long press:.......Monitor.....Monitor...........Monitor
SCR, ANI, VIB, ROGER, MR NAME all seem to do nothing. There are many more oddities and differences. At least my dial cover stays put.
And worst of all, there is no way to do DTMF that I have found!
73
Pres W2PW
KD8DVR
Columbus, Ohio
It's not mdc1200. It's MSK. A few Puxing models use this. It's an alphanumeric data burst, if so programmed.
Sent from my SAMSUNG-SM-G920A using Tapatalk
