have two Baofeng radios with audio problems.
teufler
ST PETERS, MISSOURI
Had pretty good luck with Baofeng radios but have two, one an early uv5r and one a recent GT-3. Audio comes through the ear phone jack but not through the radio speaker. Have verified firmware at n5r2401, if firmware is the problem, but nothing seems to resolve the problem. HAve other GT-3's out of the same batch and they work fine.
FKimble
Newnan, GA
Sounds like the metal tab in the speaker mike jack was not made of a springy metal and has taken a new shape from having a speaker mike plugged in and it no longer makes connact with the speaker connection.
teufler
ST PETERS, MISSOURI
it was the metal speaker tabs. used a 3.5 mm speaker plug ands inserted it several times, then powered the radio again. Presto got sound. Have not tried to put a program cable or external speaker mic back into the radio. For now I can manual program and I'm fine with that.
I only have had experience with the uv-5rs. I have heard that there was a defect with the audio jack that if used will eventually disconnect the speaker.I think it is possible to buy parts & possibly is fixable.
