is there a way, on a uv8 or uv5
teufler
ST PETERS, MISSOURI
to set up a repeater direct or a reverse repeater, with out just programming another channel. Several radios I own have this feature, just can't seem to get a one button change for going direct or going reverse .
popnokick
Northeast PA
I posted the same question here months ago. Never had a reply.... and I think the answer is, "There is not a way to do it."
khaytsus
Some have Reverse, others don't.... Even if they do, it's buried in the menus and not worth the trouble to dig out.
Personally what I do if I'm _that_ curious; switch between VFO and repeater... Just plug the input into the VFO.
teufler
ST PETERS, MISSOURI
Best I have done is just put three channels together. The repeater combination, direct and then reverse. Takes up channel space but there are not that many ham repeaters around anyway. Public service is or has gone the way of p25 digital, so its not much of a scanner anymore. Rural areas, its fine but the metro areas, its obsolete.
nd5y
Wichita Falls, TX
On the UV-5R and UV-82 pressing the *SCAN key momentarily puts the radio in reverse mode (swaps transmit and receive frequency) and shows a small R on the top line of the display.
teufler
ST PETERS, MISSOURI
Thanks, the f8hp manual does not show anything about a reverse mode. Even downloaded a pdf file and searched for the word reverse , an nothing. Anyway this will save 5 or 6 channels from being programmed.
KC9HI
Look again...
Chapter 2 - Getting to know your radio, page 20: Star * Key
"A short momentary press of the key enables the reverse function (See chapter 11 Repeaters)"
Jim KC9HI
teufler
ST PETERS, MISSOURI
thanks, I searched by text string and reverse didn't show, but its there , when I got my manual and went to page 20. now if I could get the radio to scan groups rather than the entire radio
nd5y
Wichita Falls, TX
Baofeng radios don't have groups or banks.
All you can do is set a scan list of the channels you want to scan using the Skip column in Chirp.
Any channels you add by the keypad are automatically added to the scan list. The only way to disable them is with Chirp or other programming software.
