Baofeng UV-6R
n5zjb
I recently purchased this UV-6R and set it up to be a scanner for local police, etc. I do have it working and scanning but sitting it next to my radio shack scanner I find that it never stops scanning even when it should. It will receive traffic when not scanning and just sitting on a channel but it will not stop scanning so its useless. Does anyone know why this would be? I can't find any settings that would stop the scan feature from working.
Lawman51
TN
It sounds like you have an issue in the programming. Did you use the software to set it up or do it on the keypad? I have a F9V2+ and it works fine in the scan mode for public safety.
pto
Grundy Co. IL.
Take the PL, CTCSS out of the radio,,, Above a particular step...
It is a fact that These radios will not <scan> above a certain PL, CTCSS.
I have one, (do not use it much), and have programmed several for others,,
they work fine.
OK, I have Motorola,, Kenwood, Yaesu, Vertex,,,, I lost count...
Lighten up.
Let the rants begin... JoeyC,,, You first.........................
pabloc
Ponce, Puerto Rico
I have the same issue. Please let me know if you found a solution
jonwienke
More Info Coming Soon!
VA
Does it not receive anything, or receive for a second or two and then continue scanning?
KD8DVR
Columbus, Ohio
Why would you buy a transceiver if you already have a scanner? The scanner has a much better scan speed.
sefrischling
Public Information Officer
New London, CT
I started using a UV-5X3 with only six channels in it to replace two Minitor pagers. I have scanners, I have Moto XTS 3000 and XTS2500 radios, but the UV-5X3 is nearly the same size as a Minitor V, while being able to scan VHF and UHF ... if only it did low band it could replace all the pagers.
Yea yea it'll never really replace the pagers. It can't alert with tone or vibrate, it is not nearly as durable, and other issues ... but for the most part ... with only six channels in scan it is pretty darn good for $45. Fits easily into a Minitor V case also.
KD8DVR
Columbus, Ohio
Ok. Yeah. 6 channels wouldn't be too bad. The scan speed has improved over other models.
AntiSquid Disclaimer: All posted content is personal opinion only and may not imply fact or accusation.
Ziggy925
There are some videos on YouTube regarding the Baufeng and scanning. You will have to use software and a cable to make this work.
